Another Vn series 1 overheating
hey i have a vn series one exhaust system, pod. when i first got the car i put a new thermostat in ( taking throttle body off ) BI**H of a place evrything working fine. bout 2 months ago started chewing through the water like 2 -3 litres every 3 days. i dont no where its coming from its not leaking under neath could it be the thermo and the reason y im not seeing water could it be its going onto the trans and burning away i dont no wat to do without taking it to a mechanic if u can help it SOS!!!
You could have a blown headgasket
do you have a radiator cap? check for murky water. yeah thermostat is a bad place, have you checked it since?
let the car warm up turn the heater on and just check the whole system for leaking water.
flush the system and check to coolant, replace hoses if u want, if it still happens.....you have a problem :P
