Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Spoiler weight
    VP Executive R-spec
    Jan 2005
    Default Spoiler weight
    Can someone go and grab one of those factory vp-vs? spoilers and weigh it for me :0 I want to see if it's worth pulling off
    VR Commodore V6
    Sep 2008
    Sydney NSW
    LOL.
    Your all for pulling an extra 10-15kg off if you can. Aren't ya?
    Sorry though, I'm not sure.
    VP Executive R-spec
    Jan 2005
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Morton's Avatar
    Fairstar the Funship
    May 2006
    You bet mate, I've gone to extreme lengths to remove less than that.
    Remove it ten times, and you've almost got the difference between a V6 and a V8 in terms of weight.
    From memory greenfoam, mine was maybe two? kilos... they're fairly hollow, but it's so hard to judge weight over such a large distance But I'm putting my money on 2kg or just under.
    Then you need to remove your door strips, rear garnish, speakers... (speakers are heavy)
    The 1972 HQ Kingswood
    VP Executive R-spec
    Jan 2005
    5 kilos wont show up on the street because removed from the back off the car it will only show up as more wheelspin, however it would be enough to show up on the drag strip. But Like Morton said it all adds up. You could say all the 5 kilos I've removed from my car all did nothing, but once you add them all together it's half the reason it makes good times. If I can remove 100 pounds from the car it'll be a 13 second car and a spoiler is just one step closer to the goal. Lets face it if I wanted a spoiler again later on for actual aero advatnage I could do alot better than a factory one
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    just take it off 4 the strip then back on 4 the daily? its wat 4-6 bolts? dont 4get 2 weigh them 2 hahaha stop **** fartin around jason haha
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Morton's Avatar
    May 2006
    They're usually 4 bolts, but it's the black silicone used to seal them onto the boot that can often be the killer. Here's hoping yours doesn't have any greenfoam
    Also, speakers. Now. And don't forget to empty your windscreen washer bottle and coolant overflow tank.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    2 - 3kgs at the most I would suspect.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by Morton View Post
    Ziff I have speakers and washer fluid, I'm not a complete panzy.
    That reminds me at the drags last time out I changed my dial in time and the guy was using hand signals to tell me to spray the window and wipe the old number off, I'm like can't do it man no water:!)P and he just shook his head and rubbed it off with his hands looooooool
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by greenfoam View Post
    There is a surprising amount of weight in the stereo and speakers. I replaced the stereo with a sheet of .9 aluminum - really handy to mount gauges in too
    Reaper
    Reapers Black VP SS
    Morton's Avatar
    May 2006
    hahahaha, that's a story you'll tell at the pub when you're eighty ^_^
    What about the front swaybar? Like you REALLY need that. You and I have both driven with a broken front link-pin, it's not that bad
    VP Executive R-spec
    Jan 2005
    It's not too bad driving with split/blown out rubbers on the the link pin cause that happens everytime you go around a corner fast, but the top nut falling off at 100+ around a sharp bend and having to drive over someones bush driveway to avoid rolling the car is bad :P
    And that's exactly what it wold be like without a swaybar, no thanks, I want to keep that experience to a once only thing
    Morton's Avatar
    May 2006
    I'm in the garage heat-gunning the sound deadening out of my boot right now, so let that be motivation to you I found the old factory 60w Statesman amp under the rear parcel shelf, silly little thing That has gone straight into my box of old car bits that I have no use for but won't throw away.
    And then perhaps later this week when the weather's a bit nicer, the front and rear reo bars come out for some modification
    How much time do you have before you stage up at the drags? Do you have somewhere to leave your belongings? I'm just wondering if it's a sensible idea to develop a mufferless catless exhaust with some bolt-up flanges in the middle, which you can carry in two pieces in the boot, and bolt-on when you arrive at the strip.
    I've also noticed that the Statesman has extra subframe panels in the boot, on the sides, where the VP doesn't. VP subframe bits end around the wheel arch, leaving a big gap down both sides where you can hide things. In the VQ that subframe sheet extends all the way around to the end of the boot, and up to the top, with only tiny little holes at each end. How curious.
    It's a shame that all lightweight racing seats look wanky. It would be nice to have a modest looking pair of front seats, without silly side bolsters, which were both comfortable and lightweight. I'd pay for that.
    Hmmm... Enough brainstorming, back to the heat gun
  15. #15
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    wow yous are really padatic at try to sqeeze the time out
    if you that desprate on time get a drill out with a hole saw, swiss chesse everything
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
  16. #16
    Morton's Avatar
    May 2006
    I wouldn't be surprised if greenfoam has already done that, and my VQ is on the way there too
    Did you know that when Ferrari built the F40, the paint was so thin you could see the carbon fibre stitching underneath it? That's because even paint is heavy
  17. #17
    VR Commodore V6
    Sep 2008
    Sydney NSW
  18. #18
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    There is about 6kg of paint on a car isn't there?
  19. #19
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    get rid of it, might save a few kilo's but it will also reduce aerodynamic drag. factory spoilers are generally just that, spoilers and don't really do anything to aid downforce as the normal family wagon never goes fast enough for it to do anything other then be there for looks
    Body by Holden, Soul by Brock
    the Legend will live forever
  20. #20
    VR Commodore V6
    Sep 2008
    Sydney NSW
    How much weight do you reckon there is in the sound-deadening in the boot?
    If it's worth while, I might do it.
  21. #21
    VP Executive R-spec
    Jan 2005
    There is no sound deadner in the boot of a VN, only some of the calais's. All VP's onwards have it
  22. #22
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Hmm.
    So what could be removed on a VN to reduce a little weight.
    Nothing too dramatic, and I'm not removing the A/C system.
  23. #23
    VP Executive R-spec
    Jan 2005
    Everythings dramatic Holden don't put extra weight and cost into the cars if they don't have to
  24. #24
    VN S1
    Jan 2008
    On my house scales my Vp rear wing is 3 and a half kilos. But my misses also weighs 58 kilos... Maybe a happy set of scales rigged by her?
  25. #25
    Morton's Avatar
    May 2006
    hahaha ^_^
    3 kilos sounds about right Greenfoam, you know what to do
    And yes, everything done to save weight is drastic. Which is why I don't run aircon, and am in the market for a manual steering rack. The sound deadning in the boot (if you have any) is roughly 4kg. It's the stuff in the front footwells and around the trans tunnel that really packs a punch
  1. Will VX SS spoiler fit VX S spoiler holes?
    By grimavxs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-12-2007, 07:56 PM
  2. vs v6 weight
    By petezor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2006, 10:49 PM
  3. HELP plz.....different weight
    By crazy_wog01 in forum General
    Last Post: 16-11-2006, 09:26 AM
  4. Swap Silver Vy Boot Lid With Spoiler For One With No Spoiler
    By vy1sv8 in forum Swap / Wanted to Buy / Trade
    Last Post: 01-06-2006, 10:07 PM
  5. Changing my spoiler to A Lip Boot Spoiler
    By Sambo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2006, 07:23 PM
