Ive been busy lately on weekends stripping my donor vp for my vn, somewhere along the way ive lost my vn's keys... I can get a full set but i need to know how to remove the ignition barrel from the steering?
2nd question is about replacing lighter socket, i have a good condition lighter i want to put into the vn's console but i cant see a way of removing the lighter frame without busting something any ideas?
lighter socket, unplug it all, then at the bottom of it, you unscew the hex looking steel nut(sometimes very tight), then the outer sleeve comes off and you pull the guts out from the top.
barrel, you need an original key to get the barrel itself out, otherwise, you've gotta break/drill/saw the security bolts off from memory.
Thanks heaps hak and green.
