With the adjustable panhard rod,
What side goes on the part that needs lifting? The side with the turn able Knut/thread or the blank side
And how does it lift it higher by going outwards?
an adjustable panhard rod is used to centralize the axle on a lowered vehicle.
it can probably be fitted around either way, assuming the adjustment clears everything.
sorry but, do you know how side goes on the part that needs lifting? The side with the turn able Knut/thread or the blank side
what?
it doesn't lift anything, it moves the axle so its central.
it can probably be fitted either way, but I don't actually know the car.
so if my back left is out of wack/scrapping on body etc. what side do i have to adjust it to?
the kink in the panhard rod goes on the passenger side, its kicned to give extra clearance of the exhaust, being that the car is lower.
like its scrapping in the wheel arch when turning hard left, so still adjust it shorter?
i should have explained it better
stick the back end of the car on ramps with the panhard rod on the car
turn the turnbuckle one way, you will see the car move. if you can see the wheel move away from where its scraping, center it as best you can and lock the nuts up, if its getting closer, turn the turnbuckle the other way. failing that, take it to a mechanic.
hey thanks guys yous are legends thanks alot guys
also if you brough it 2nd hand check the condition of the bushes on the rod.
I don't thnk you would ever need a longer panhard rod with a lower car. And remember when fitting it the car can't be raised. Or atleast not when u judge the adjustment. U have to plonk the car on it's wheels to check the body movement
you'd need a longer panhard rod with a raised car![]()
