Results 1 to 9 of 9
Thread: Oh no,Water leak
    vn wagon
    Dec 2008
    Angry Oh no,Water leak
    Have a small water leak commin from edge of rocker cover at rear of engine !Cracked head,external water galley ?Should I replace Heads or can you fix it and is it worth it ?
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Are you sure its coming from the rocker cover, may need to clean the area and check again...
    VN Berlina
    Sep 2005
    water galleys dont ran that close to the side so if it was them then its ****ed anyway
    Morton's Avatar
    Fairstar the Funship
    May 2006
    If you've got water coming out of your rocker cover, I think you've got bigger problems than just a cracked water gallery lol
    As mack said, clean everything up and have another look.
    The 1972 HQ Kingswood
    vn wagon
    Dec 2008
    Thumbs up Fixed.
    Cleaned evrything till ya could eat off it,removed rocker cover,replaced,traced water from dowell in rear bolt of inlet manifold.Bottle of chemweld,no more problem,and a spotless engine ta boot
    vp exec
    Dec 2006
    vaucluse, sydney
    dont panic... had this happen a few times (on different manifold bolts) on my vp v6. i found that the inlet manifold bolts loosen over time. so i used to pull them out one by one, clean them right up (clean the shafts of the bolts, the threads etc) and then put em back in. dont overtighten them - the torque settings r in the repair manual. eventually the inlet manifold gaskets needed replacing, but thats another story. cheers
    skyper is offline SKYPER
    SV6
    Aug 2008
    LISMORE NSW
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    why did you use that crap for ? Chemiweld ? You better check if your heater is working. Chemiweld uses pices of copper/metal which melts and cools where the leak is, problem its well known to block water galleries, heater cores and the likes. You should have rather used Bars Stop leak/GM Radiator Pellets. When my inlet manifold gasket blew, it did have water coming through the manifold bolts as well and mix with oil in some parts, as well as blow the gasket.
    When putting any of these bolts back in, you are meant to use loctite to stop them getting loose.
    Vp series 2
    Jun 2008
    mate if in dought either locite or never seize. hell i wonder if i can use both?
  1. water leak
    By newbee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-07-2008, 07:44 PM
  2. water leak
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-04-2008, 10:08 PM
  3. water leak
    By andyman in forum The Pub
    Last Post: 21-08-2006, 04:36 PM
  4. Water leak
    By Emu in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2005, 12:24 AM
  5. VN water leak
    By NORTI in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2004, 12:03 AM
