hey guys, im looking at getting a vn on the weekend pretty cheap, but it overheats when your not moving anywhere, the owner went and put a new thermostat in and flushed the system but still same problem, do you think it might have something to do with the heater tap maybe? or do u think it might have something to do with the radiator? i am leaning more towards buying a new radiator as that what it sounds like to me, but before i go do that i just want to know your opinions on what it could possable be.
thanxs
Might sound stupid, but does the fan work???????
hmm didnt check that haha i will have another look on saturday when i get a proper look...
could be the water pump too!!
how can u tell if its water pump? do u look for the leakage through that hole on it? also are they just as easy to change as the vr waterpump? or is it harder
when mine was over heating it was the waterpump when i took the belt off and spined the pump it was making weird metal scraping noises and the gasket was destoryed it was leaking water.. i was being cheap so i took my mates vr water pump out of hes wrecked car, gave it a real good clean put it on my vn n never over heated!
hmmm thanks for that if i buy it i might change the waterpump first to a new one, they reasonable cheap and then that will hopefully fix the problem or eliminate the waterpump ha ha thanks, would that explain the getting hot when in slow traffic and idle and cools down to normal when going at speed..
thankyou for the help
maybe the thermostat aint working properly? do you lose water at all??
im not too sure, ill have a good look on saturday when i look at the car, its my mates dads car, and he not too sure, but when i get there on saturday i will have a look at the radiator to see if it has coolent in there.
when you go to look at it.. start the car up let it run, you said it gets hot pretty quick.. you might see if theres waterleakson my old mans vs it use to heat up around in 30mins then leak water, i open the bonnet take a look at the radiator while it was running it was cracked, but before that i changed the thermoe, waterpump to figure it coz the crack on the radiator was hidden, well anyways goodluck finding the problem it wont be something major unless its the welsh plugs
like on my vn haha the worse thing ever
ok mate thanks for that helpful info, i will let you know if i buy it and find the problem, yeah im thinking its not mojor ha ha def know its not welsh plugs thankgod, yeah welsh plugs are a pain i had 1 go when i had a vk commodore, very hard to get to
thanks again for your help![]()
hey guys, i looked at the car and it appears to be the waterpump i think, it has white dots all around it like it has leaked, that would explain why it overheats at idle and in heavy traffic, thanxs for your help guys, i will be buying it tomorrow and doing the waterpump, will let you know if it fixes the problem or not, cheers
hey i was the only one that helped youjokes haha.. thats good to hear i hope it fixes you problem
haha ha yeah your right lol. yeah hope it fixes the problem will let you know how i go.
