Results 1 to 8 of 8
Thread: Door Adjustment (VP)
    VX Berlina Wagon
    Oct 2007
    Default Door Adjustment (VP)
    gday fellas, just wondering if anyone knew how to adjust a door so it is flush with the rest of the panels as my doors arent completeely flush..Help?
    skyper is offline SKYPER
    SV6
    Aug 2008
    LISMORE NSW
    mate either the door or the car is bent,what part is not flush,the doors have no ajustment but their ways around this
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    the only things you can do are replace the hinge pins about $10 each door for both pins or you can adjust the striker so the door shuts closer
    if none of the above work then you have to get brutal and start bending things if this is the case the car has been in an accident and could make your life hard trying to get them right
    if you pop into a crash shop they should be able to tell you straight up (for free) what is causing the trouble
    im not admiring your car im looking in disgust
    92 VP SS rep
    Dec 2008
    Adelaide SA
    I have a similar problem, its hard to close the doors so they are flush.... i had the window motors re-done, so would it be correct for me to assume that they diddnt hang the doors properly?
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    not 100% sure in your case, but I would very much doubt they took your doors off when you got your window reg motors replaced.
    SV6
    Aug 2008
    LISMORE NSW
    guys the doors only go in one spot ,weither u take them off and on 50 times they will go back in the same spot their on pins,where do u guys mean when u say flush,with sill ,back door,front guard,what
    VX Berlina Wagon
    Oct 2007
    Quote Originally Posted by skyper View Post
    just with the rear quarter and the front quarter.....the actual doors are both flush with eachother...
    VS Calais
    Apr 2005
    If the doors are sagging the solution is a trolley jack and a plank of wood...
  1. handbrake adjustment
    By SweetWagon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-11-2010, 10:00 PM
  2. AFM adjustment
    By hertygerty in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-09-2007, 01:15 AM
  3. VT Handbrake Adjustment
    By sharpeidog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2007, 06:12 PM
  4. headlight adjustment
    By kingswood75 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-03-2006, 01:54 AM
  5. after camber adjustment
    By judd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-07-2005, 09:32 PM
