just put new shockers in and have this annoying rattle/knock ive tried all the ways i no to make them knock when its stoped,is their a test,how would u make sure its not them ,the noise is not loud just annoying,more in one side ,and yes checked everything eles,it sounds like shocky rattle/knock but their new
The nut that holds the shocker in has probably worked loss, pretty common. Loctite and a bigger spanner next time
Yep...+1 for that. You have to do them up really tight. Check the top nut as well.
i thought of that but have not check them yet,done the top ones ,ill do that ,thanks guys
Had the same problem and it turned out to be the shock nut...
