Results 1 to 13 of 13
Thread: Sway Bar Link Pins
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Default Sway Bar Link Pins
    How do i know when ive done them up tight enough?
    Sorry if this is posted somewhere i dont have time to do a good search cause im running late and the cars got 2 wheels missing
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Jun 2005
    if aftermarket, ive read that they just get tightened up enough for two rubbers to start pushing against each other. thats what i did with mine and no problems so far
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Don't forget, you should ideally tighten them with load on the suspension
    But yes, as tight as is "sensible". Not so tight that you go red in the face, but a decent effort.
    The 1972 HQ Kingswood
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    By load dose that mean having the car on the ground, how the hell do i reach them then?
    Anyway just done them up so i couldnt squeez the rubbers with my hand and then some
    The Daily VN T5V6
    355 VN GRP A REP
    Morton's Avatar
    May 2006
    Yeah, car on the ground. Otherwise they're tightened up out of shape. You get under there by driving the front of the car up onto ramps, or lowing the front wheels onto some blocks of wood.
    Or, suck the belly in and squeeze under there like I do
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by Morton View Post
    Should be able to do that, im small enough
    The Daily VN T5V6
    355 VN GRP A REP
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    but your a stick :P lol
    i done mine up "fairly" tight, pretty much what morton said before...
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Yeah well i pretty much have to do it without ramps, my ramps dont agree with my front bumper
    The Daily VN T5V6
    355 VN GRP A REP
    Morton's Avatar
    May 2006
    Drive the car up onto short wooden blocks before the ramps
    Quote Originally Posted by padrickz88 View Post
    Yes, yes I am. That's how my cars go faster
    VP Executive R-spec
    Jan 2005
    That's what does it for me too, you can't bet the guy next to you if he's got the same car and weighs 50 kilos less, even the flawed Human version of phsyics doesn't allow it, as for ramps. Last time I had to get my VP on ramps it took lots of wheelspin, some sideways action down the hill, planks of wood, cardboard, mowing the grass and finally after an hour a big run up and some braking skills before I got it on
    Vp series 2
    Jun 2008
    nah mate just do them up till a little after the bushes startto clamp. I spat a set of nolothanes out the side buy do them up tight, well firm by my standards.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    I think the instructions that came with mine say go till there is no play left in them, then a third of a turn more. Or to 20 newton metres.
    Mine come loose so often that I am able to crouch down beside the car, reach around behind the front wheel and tighten them without needing to crawl under the car. Also - its a good idea to put an extra nut on (like the nuts off the ones you just removed) and tighten it against the nut on the link pin to lock it shut. Nylock nuts do sod all - mine always work loose.
    Morton's Avatar
    May 2006
    Quote Originally Posted by greenfoam View Post
    Yes, but the rest of us aren't trying this stunt on a waterlogged field I know this comes as a shock, but some of us have sealed driveways ^_^
  1. VT Series II Sway bar link pins
    By TGibson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2011, 07:01 PM
  2. Adjusting stablizer link pins
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2008, 07:45 AM
  3. vr link pins
    By vnholden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2008, 09:20 PM
  4. Swing arm link pins...
    By JBDrifter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2007, 01:52 PM
  5. Link Pins (Rods)
    By hsvd_g in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2005, 10:52 AM
