Results 1 to 18 of 18
Thread: engine to transmission
    NO CAR ATM.. -.-
    Jul 2006
    Default engine to transmission
    been trying in and out and that wont go in?? is there a way or a something to put it in there ive tryed about everything!!! thats the only one that doesnt go in help mee
    Attached Thumbnails Attached Thumbnails engine to transmission-s1ut-wont-go-.jpg
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    auto or manual?
    If auto i'd say the the 2 notches on the torque convertor aren't lined up properly
    If manual i'd say it hasnt lined up correctly try moving the rear of the box over slightly. If its an auto this might help out aswell.
    It's hard to tell from looking at the picture and tell what the go is. If your ABSOLUTELY POSITIVE everything is lined up correctly use the bolts on that side to help even it out and pull it flush with the block
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    NO CAR ATM.. -.-
    Jul 2006
    its auto, that picture is taken from the passenger side all the bolts are lined up, that is the only part of the transmission that wont go in, its only in by 2mm or something, wateva i do it doesnt gooo
    NO CAR ATM.. -.-
    Jul 2006
    ok i figured that part out.. damn it was annoying now upto the engine mount parts..! and tips on putting them on without killing myself?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Yeah, all you had to do was lift the back of the motor up to come into line with the transmission. Then it would all slide in.
    The best way to do engine mounts, is one side at a time. Support the engine by the sump, with a large, wide slab of wood. Use a GOOD jack, with a LARGE head. A big garage jack or something similarly stable. Then use it to raise the motor and to the mounts one side at a time. You can safely get away with raising the engine... it looks like a V6 from that angle, so roughly 10cm. On a V8 you have to worry about coil and dizzy clearances at the firewall.
    I did both engine mounts in my VQ in about 45min.
    The 1972 HQ Kingswood
    NO CAR ATM.. -.-
    Jul 2006
    thanks for your replys guys.. i ended up going outside and figuring everything on my own thanks for your replys anyway it would of been useful if i hadnt of figured it out! by the way its a vr motor bolted onto a vn transmission allmost finished putting it all back together it got dark n mozzi's are everywhere
    NO CAR ATM.. -.-
    Jul 2006
    and and about the engine mounts i ended up taking the passenger side off too.. removed the aircon gonna get a shorter belt all aircon cra p was removed b4 anyways
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    way to go with the no aircon much easier doing stuff without it there. So what ended up being the issue?
    When i built a motor for my mate it took us longer to fit the y pipe than to remove and install new motor. have fun with that part
    NO CAR ATM.. -.-
    Jul 2006
    haha yea i removed the aircon gas tank, the cooler and lines like 4months ago so no use for it anyways, yea im upto the Y pipe now im not having troubles with it, its kinda easy from now on .. i just have to go wreckers tmorow n get some hoses.. ill post wen im stuck coz the vr manifold is kinda different then the vn one
    Vp series 2
    Jun 2008
    vr manifold and series 1 vn are VERY different.
    if your old manifolds look like cheap crappy extractors then you will need another y piece.
    Morton's Avatar
    May 2006
    It's not like you need aircon down here in Vic during summer anyway. Hell, it was... what, 19 today? Gawd.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    it gets hot though was over 40 a couple times last yea. I'm not a fan of air con myselfif it doesnt work i'll rip it out if it works i keep it till it stops working
    VP Executive S2, VL 5sp Berlina Wagon
    May 2008
    Down South, Adelaide
    who needs aircon, ive got it and works perfectly but only ever used it to make sure it works in the 9 months of owning my car, window down works perfectly
    Sleeper Wagon - In the Build
    VP Executive series 2
    Check out My Ride
    Current Mods
    Widened S/C CAI, 2.5" exhaust, Advance headers, no bellmouth, 17" VY SS, Foamy Tune
    Future Mods
    New Car
    Wanted
    MONEY!!!
    NO CAR ATM.. -.-
    Jul 2006
    centy i dont need no Y piece... im using my vns one + i dont think the vr oxygen sensor is the same as the vn onee.. but now i got most of the stuff on its all matching up good!! just some problems with the ecu loom.. =[
    and about the aircon.. i never regased it since i brought it haha =]
  15. #15
    Pumkin chariot
    Oct 2008
    Quote Originally Posted by Pub24/7 View Post
    haha, i had that very same problem with my vn spent a couple of hours just trying to force the right side of the y piece past the steering rack and bellhousing, until i decided to give in and take the tailshaft and gearbox crossmembers back off...jacked up the back of the box and the pipe just slid straight in. dont know why i didnt just do that in the first place
    first time ever doing an engine swap...gotta say i learnt a lesson that day
    Quote Originally Posted by STEALTHY™ View Post
    It could have had a boeing 747 engine too (assuming all the VL wankers havn't snapped them all up)
  16. #16
    NO CAR ATM.. -.-
    Jul 2006
  17. #17
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by h0Ld3n`VN View Post
    i dont get why its so hard.. mine bolted up fine it was easy
    It's quite a bit harder when you got an abs module in the way. Also we did try it the hard way eventually we just undid engine mounts and pulled the motor up some more. Tom had also cut the bolts off as he couldnt get them undone. so they were drilled out and new bolts put through it was quite diffcult trying to stop it turning whilst you did the nut up
  18. #18
    NO CAR ATM.. -.-
    Jul 2006
    what the heLL.. lol =/ that woulda been a headacee
  1. vn engine and transmission
    By MUNTED6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2007, 11:10 AM
  2. Engine VS Transmission
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2007, 04:21 PM
  3. Engine VS Transmission
    By cypher967 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-01-2007, 01:57 PM
  4. Transmission fluid in engine bay
    By iansown in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2006, 01:31 PM
  5. transmission and engine light
    By nathsvrbt1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2006, 03:14 PM
