Results 1 to 4 of 4
Thread: Lining up the gear box to Converter
    VNCPTR is offline Banned
    90 S2 Atlas Grey VN SS Manual
    Dec 2007
    Default Lining up the gear box to Converter
    Hey all,
    Im changing the Torque Converter on my wifes VP V6 and i was wondering is there a certan way for the gearbox to be lined up to the torque converter?
    Or can i just put the box to the motor and bolt it up and should be fine?
    Cheers VNCPTR
    Feb 2004
    Quote Originally Posted by VNCPTR View Post
    Hey all,
    Cheers VNCPTR
    what u have to first of is make SURE u install a new front pump seal , and make sure the seal retainer is put back on...
    ( poorly designed front pump section, the retainer is there to stop the front seal popping out..but this can be fixed , by removing front pump assemble and drilling out the hole behind the seal bigger....)
    anyways , as you slowly start to put the torque converter in , spin it around by hand , either clock wise or anti clock wise, until it goes all the way in , it KINDA clicks in 3 lots ??? you will know u got it all the way in when the locating bit in the middle of the converter is flush with the face of the trans , where it bolts agains the motor.....
    VT spac super6
    Nov 2008
    Riverton sa
    as said above with the converter off of the motor line up the dowls on the noise of the converter to the oil pump inside the trans untill its conpletely in
    fairly common for people to miss this n try pulling the box against the motor with the bolts which smashes the front of the pump in
    VP ute
    Mar 2006
    and that would just answer why after having a engine fitted by Veale the pump seal went very soon after
  1. Roof Lining
    By VRTurner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2011, 05:54 AM
  2. Redline 1st gear & 2nd gear...weird
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 09:02 PM
  3. hood lining
    By schadenfraude in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2005, 05:46 PM
  4. roof lining
    By dando in forum General
    Last Post: 14-07-2005, 02:06 PM
  5. Roof Lining
    By MuNtEd in forum General
    Last Post: 27-09-2003, 10:48 AM
