hey guys still putting everything together and i came across the, ecu wiring loom where the plugs go in the sensors injectors etc.. i still have the s1 loom in there everythings so weird? i need the s2 loom yeah???
when i mean weird is the sensors are too long/short because the s1 block is way different as everyone knows, jason aka greenfoam said to extend the sensors wires and solder to fit? is that what i should do.. damn wreckers closing in 10mins i was just there aaaaaarh![]()
yeah you could lengthen them wouldn't be an issue check they all work afterwards. Or you could get a s2 loom
Originally Posted by Smidy
i made the wires longer and all but i was wondering which one goes in the block and alternator.. its like i have one extra plug???
edit: just to make it clear.. the loom thats attached to the motor is the vr one that came with the motor.. and i have series 1 ecu loom it was allready attached to the car
so the blue and the black is from the vn s1
brown from the vr s2
The brown ones the alternator far as I can remember and the blue one is the water temp sensor, Ill check in a minute
brown and black are alternator...... on the vn's they had the alternator plug on the loom that goes into the dash and on the vr's they had it on the loom that goes on the engine....
weird! and as jason said blue is the coolant temp sensor, i had to lengthen the 2 coolant temp sensors (dash and ecu) to the front of the block aswell...
pretty much from my experience you need the vn loom on the vr engine aswell instead of the vr loom..
i would tell you how my engine is going but im having other elecrical problems not related to the engine (hate it when previous owners stuff around with **** then when i go to fix something i have no idea)
im just gonna get a vn s2 loom 2morow i wanna still use the vn ecu much easier less complicationss.. for now im gonna tighten most bolts make sure there secure and all and look over the whole engine bay so that if im missing something![]()
mmmm jolly rogers all you can carry for $99
yea was there yesterday :P but i didnt need much haha total of $28 =[ how much is the s2 eculoom anyways?
lol idk we were there yesterday shopping trolley stack 8 foot high with tyres :P mate scored a full set of vp ss rims only 1 center cap though
i think i saw that!! hahaha with the ss rims :P i went around 12-1 or sumthing![]()
we were there till closing time mad rush at the end to find some more good tyres to get our 100 worth
