Results 1 to 24 of 24
Thread: Harmonic balancer swap... Question!
    VN S1
    Jan 2008
    Default Harmonic balancer swap... Question!
    Hey lads my vn's harmonic balancer is showing cracks on the outer front. So im thinking of swapping it over for my vp's.... Is it possible to swap them or is there changes from the years? And or cos vn's manual vp's auto.
    Note: Not impressed, after finding out what i thought was a water pump failure turned out to be a freakn leaking welsh plug...
    Jul 2008
    If the vn is a series 2 then it sohuld be a straight swap, the main diff between the series 1 and 2 in the spaces on the back for the crank angel sensor are different.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yeah to be safe swap the cas aswell that way you got no dramas which plug was leaking one on the heads?
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VN S1
    Jan 2008
    The welsh is the drivers side rear (facing the right guard). But ill do all the ones i can get to without having to take the motor out...
    Id love to take the engine out and do the welsh plugs and run a new set of gaskets through it, but i havent got the equipment to do it.
    I think its a S1 vn and a S2 vp. Will it still work to change both the balancer and c.a.s?
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yep should work fine
    VN S1
    Jan 2008
    I was lookn at gettin a powerbond balancer overdriven but it suits the supercharged ecotecs more.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    I found that the timing cover is different and with the CAS the base of the sensor is flat where the VP CAS on the hole that the bolt goes through the base is lifted a mm or so so when you mount your CAS on there it will snap it, thats in my case when i tried it on a vp timing cover with a vn CAS, with yours if your using your VP H/B and CAS just compare the 2 and look at the base, i think they did it in the VP for more accurate timing for the sensor, just a heads up if its the same problem.
    ~ VN POWER ~ Click the scales
    VN S1
    Jan 2008
    Oh damn although i can get a harmonic balancer to suit pretty cheap, was the bonus of a new cas that lead me to want to use the vp's harmonic.. Atm the vn's harmonic balancer just has a few crack lines appearing in the rubber. But may as well replace it while engines are out.
    VT SS 5.7
    Mar 2005
    Goulburn
    Quote Originally Posted by needwork2-4fillhabbit View Post
    What kinda pulley are you gonna use to swap the balancer?post pic if possable coz i gotta do that same job myself
    i have a bosch kit pulley but i dbout that will work on the harmonic balancer
    Real cars don't power the front wheels, they lift them
    VN S1
    Jan 2008
    I bought a harmonic balancer puller from supercheap 25 bucks.
    Attached Thumbnails Attached Thumbnails Harmonic balancer swap... Question!-puller.jpg
    VT SS 5.7
    Mar 2005
    Goulburn
    sweet thank you, now i know where to score 1 from i guess ill be busy for the rest of the day lol .what are they worth in price ?
    VN S1
    Jan 2008
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Hey mate i did mine on my seires 1 vn today after it left me stranded on the side of the road yesterday. A few things firstly i dont think you'll have much luck with that puller as theres nowhere to bolts through. I used a 3 claw puller and either grab it around the outside or if the claws are thin enough in the slots on the inner hemisphere. VN s1 use a different style cas and you have to adjust them once you put the balancer back on make sure its not fouling and sits correctly then tighten the bolt that holds it in place up.
    There's no difference in where any of the holden v6 cas mount on the timing cover i dont see any reason why you couldnt use the later models my only issue now thinking about it is make sure the belt lines up correctly.
    Also another thing 1 1/8 socket was needed compared to the 27 i used on my vp what a bitch i had to walk to a mechanic twice to borrow the correct socket
    VN S1
    Jan 2008
    Damn stupid puller.. guess i could still rig something up with it but... Thanks for the socket sizes also had a quick look today and not one laying around to fit either lol. I might just swap the puller for a 3 piece puller like you used.
  15. #15
    Black VN MANUAL
    Feb 2007
    Top of Vic
    i'm pretty sure there is a difference because i broke 2 CAS before i found the problem out, compare the difference with the VN CAS to the VP CAS, unless the wreckers gave me a VR timing cover i dont know it said VP on it, just have a look at the 2 and see.
  16. #16
    VN S1
    Jan 2008
    Ok mate ill have a good study of them both once there side by side, also im not sure on the injector numbers you need off the cream tops.
  17. #17
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Yeah i dunno if you can just grab them out of any magna like a te tj or is it a early model. but yeah, just look at the CAS where it mounts and the timing cover its 1mm difference
  18. #18
    VN S1
    Jan 2008
    When i searched my wrecker for them he said he thought they would be on the te but we didnt find any laying around, we found 3x green injectors from a ford that would have been great if we couldve found 3 more lol. Wheres stocky when you need him. Although i think i asked him bout the magna injectors earlier in the sc14 post.
  19. #19
    Black VN MANUAL
    Feb 2007
    Top of Vic
    IS there any other models that will have some good injectors, i dont think there is any S/C v6 ones there.
  20. #20
    VN S1
    Jan 2008
  21. #21
    Black VN MANUAL
    Feb 2007
    Top of Vic
    My mate was just going to score them for nothing and give em to me, thats why i wanted some part numbers so i can tell him what 1s and then tell foamy that i got some and get a tune set to them.
  22. #22
    VN S1
    Jan 2008
  23. #23
    Black VN MANUAL
    Feb 2007
    Top of Vic
  24. #24
    VN S1
    Jan 2008
    Seems most places sell them as a standard one size vn-vs harmonic balancer. So it looks like its just finding the cas to suit. I have one on the vn now and one on the donor vp so ill just have to try em out and see when there off (tomorow). The vp one is relatively new and would be great if it fits.
  1. Harmonic balancer question
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2006, 07:20 PM
  2. Harmonic Balancer...
    By sicko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2006, 08:09 PM
  3. Harmonic Balancer
    By PIMPIN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2005, 11:21 AM
  4. Harmonic Balancer
    By rodge26 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2004, 07:30 AM
  5. Harmonic Balancer Question/help
    By zerosin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2004, 10:11 AM
