Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: vn still overheating
    None
    Aug 2005
    Adelaide, SA
    Default vn still overheating
    hey got a dec89 VN commodore and i have changed the waterpump and thermostat and it still seems to overheat, the radiator looks fairly new in the car, so what else could it be? i noticed that i can see and hear water sizzling by the L/H rocker cover gasket (passengerside) so what could that possable mean? would it be cheaper to get another motor put in as i can get one for $1000 fitted?
    cheers
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Water at the rocker cover gasket? I don't think that's normal.
    Are you constantly having to fill the water up in radiator at all?
    None
    Aug 2005
    Adelaide, SA
    yes i am now having to constantly fill it up, but theres no milky oil so thats where im getting confused. what could it be?
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Well then there's a good chance that your head-gasket isn't blown.
    What about your welsh plugs? Are any of those leaking?
    None
    Aug 2005
    Adelaide, SA
    i might just go out and have a look, where abouts are the welsh plugs located on the vn motors, i have the morot with the thermostat at the back of the motor
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Inlet mainfold gasket is most likely culprit if you hear it leaking near rocker covers.
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VR Commodore V6
    Sep 2008
    Sydney NSW
    None
    Aug 2005
    Adelaide, SA
    oh right, yeah i hear it and see it sizzling and its leaking at the top passengerside rockercover closest to the throttlebody end
    VR Commodore V6
    Sep 2008
    Sydney NSW
    None
    Aug 2005
    Adelaide, SA
    None
    Aug 2005
    Adelaide, SA
    yeah up the top
    where i have circled is the area where the water is leaking from
    VR Commodore V6
    Sep 2008
    Sydney NSW
    I'm not 100% sure, so anyone who know's otherwise, please correct me if I'm wrong, but there maybe a possibility that you manifold gaskets gone, and leaking water.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    inlet mainfold gasket as i stated above
    None
    Aug 2005
    Adelaide, SA
    sorry this is gunna sound stupid but where is the manifold gasket and how hard is it to change?
  15. #15
    None
    Aug 2005
    Adelaide, SA
    also does the rockercovers have to come off? is it reasonable easy job to do? what has to come off do you know? and is the manifold gasket where the 3800 sit on top of ?
    also would it cause it to overheat? as when it starts getting hot i can hear it bubble back into the overflow bottle, but when it cools down i still have to put a fair bit of water in it
    Attached Thumbnails Attached Thumbnails vn still overheating-picture-001.jpg
  16. #16
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    no raocker covers dont need removing but changing manifold gaskets is a big job. Basically the whole manifold between the heads needs to come off. The gaskets that need replacing are between each head and the manifold. gasket set is about $30 and you'll need to drain cooling system, depressurize the fuel rail and disconnect the hoses at end of the rail all other obstructions removed. Theres about 8-10 bolts the need to come out and then whole manifold will lift off replace gaskety and rubber seal at front and back of block the install is reverse of removal
  17. #17
    None
    Aug 2005
    Adelaide, SA
    no worries, so do i just ask for a manifold gasket set or a water manifold gasket set?
    also how do i depressureize the fuel rail? take the vaccuum hose off?
    and would that still cause it to bubble watter backinto the overflow from radiator when hot?
  18. #18
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    ok ask for an inlet manifold set to suit vn s1 there might be 2 kits one will just be gaskets the other will have things like the thermostat housing gasket. get the bare kit. depressurising fuel rail is done by removing fuel pump fuse and cranking engine for a bit.
    Yes it can overflow to bubble as pressure is forced back through cooling system
  19. #19
    None
    Aug 2005
    Adelaide, SA
    cool, thankyou for your help, much appreciated, now ill see if that fixes the problem hopefully
  20. #20
    None
    Aug 2005
    Adelaide, SA
    so the throttle body has to come off does it? also when i undo all bolts i can change both sides at the same time with the inlet manifold?
    also here is a picture of the gasket set, what ae the 2 blue long thingd for?
    Attached Thumbnails Attached Thumbnails vn still overheating-picture-002.jpg
  21. #21
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    you amy get away without taking tb and elbow off though it could give you more room. Yes change both side the other one likely on the way out. The blue things are the seal for front and back of block when you pull it off you'll see where they go
  22. #22
    NO CAR ATM.. -.-
    Jul 2006
  23. #23
    NO CAR ATM.. -.-
    Jul 2006
    here u go a picture.. some1 could mark the picture on paint or something to show u where they all go.. i cant remember exactly what the gaskets are called
  24. #24
    None
    Aug 2005
    Adelaide, SA
    well i changed the manifold gasket put it all together now it has a loud hissing sound and reving high? what could that be?
  25. #25
    NO CAR ATM.. -.-
    Jul 2006
    what kind of hissing?? like water touching hot metal like ur extractors? firstly clean ur engine with degreaser so its easier to see where ur problem is its dirty as
  1. VP V6 Overheating AGAIN!!!!!
    By Cobez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2010, 08:18 PM
  2. Overheating ??
    By blade002 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 12:35 PM
  3. Overheating? Cause?
    By FullySick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2008, 06:14 PM
  4. Overheating
    By Turbo_dreams in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-04-2006, 09:37 PM
  5. VH 308 overheating
    By jlenon in forum General Discussion
    Last Post: 05-02-2006, 06:02 PM
