Results 1 to 11 of 11
Thread: Exhust help
    vn90
    Dec 2008
    Default Exhust help
    few ppl have told me i can join the trail pipe n muffler by sliding them in with hi temp sillcone to hold it tighter im woundering what u guys think about tht
    and wat shud i do about tht lil 7mm hole can i get repair kit or am i gonna have to get it welded
    Morton's Avatar
    Fairstar the Funship
    May 2006
    That orange high-temp silicone stuff is damn strong. Most of my flanges use that stuff instead of gaskets - many a trip to near 5000rpm has still not seen them fail Just pack craploads of it in.
    You're probably also well off getting an exhaust clamp and using that - they're cheap.
    The 1972 HQ Kingswood
    vn90
    Dec 2008
    AND what shud i do about this lil hole im shud i get get them old bits were its been welded grided off then get it filled buy welder or just fill with sillcone n i dunno something tht will fix it quick n were i shud go to get it done pic shud be below of hole
    vn90
    Dec 2008
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Just take it into an exhaust shop and they will weld the hole and fix it, if the rust isnt to bad might have to get it replaced. but for the other bit where it slides in high temp sealent will do the job fine, it has also stopped my extractor leak
    ~ VN POWER ~ Click the scales
    vn90
    Dec 2008
    cheers how much u rekon it wld cost to fix tht hole n
    its barly rusted at all just look it in photo cos its bright
    only payed 90 bucks for hole thing so was bargen has nice crome tip so its good
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Yeah well if you take it into the place not on the car, shouldnt be over 10-15bucks cause its stuff all work its a 2min job, then fit it yourself use high temp sealant on that join and where it bolts up to the cat. should be good.
    vn90
    Dec 2008
    thanks heaps mate lets hope it sounds good on car
    shud i go a garage or a exhust place
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Exhaust place, garage will charge you by the hour and take there time.
    vn90
    Dec 2008
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Pacemakers, 2.5mandrel bent exhaust from ebay (new) $160 fitted the extractors myself and exhaust, extractors where $150. sounds good with a manual makes a differents. good luck with your exhaust.
  1. Exhust pipe help
    By MAC-VN in forum General
    Last Post: 22-12-2008, 01:51 PM
  2. vn - vr v6 exhust manifolds???
    By VR 3.8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2007, 10:49 PM
  3. exhust help
    By reaper115 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-08-2006, 09:59 PM
  4. whats a good exhust system to put on a vx s2?
    By diontanti in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-07-2006, 10:59 AM
  5. Vp Exhust system
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-01-2005, 08:09 PM
