Results 1 to 4 of 4
Thread: Question - Easy
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Default Question - Easy
    on vn - vp where is the "ignition module" located
    and what is the main purpose of it
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    dunno about the ignition module, but the ignition coil is on to p of the dfi module, that could be what you mean, it's the bit with the lead going to it on the front top of the passenger side of your engine.
    basically provides current to the spark plugs so the engine can ignite the fuel.
    COMMODORE VP
    Dec 2008
    Default also
    is it possible to replace the crank angle sensor with out removing the harmonic balancer
    cos i read that it's right behind it, which is about right
    VR BT1 V8
    Jan 2009
    Geelong vic
    You need to remove the harmonic balancer to remove the crank angle sensor. The harmonic slots into the crank angle sensor and when you remove it be ware of bending the fins on the harmonic. there a tuned distance between the grooves of the crank angle sensor.
  1. How easy is my car to steal? VX S Kill Switch Question
    By steveo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2011, 05:19 PM
  2. Easy 5.7L Question
    By Darren in forum General
    Last Post: 29-10-2006, 08:11 PM
  3. An easy question
    By Mr_Slim in forum Electrical Wiring / Questions
    Last Post: 11-06-2006, 11:32 PM
  4. An easy question
    By Mr_Slim in forum Car Audio
    Last Post: 07-06-2006, 08:01 PM
  5. easy question
    By Red_dwarf10 in forum Car Audio
    Last Post: 01-02-2006, 06:41 PM
