Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: supa 6 or 5L
    VN S
    Dec 2008
    Default supa 6 or 5L
    ok so im toying with the idea of a new motor, ive got a couple options floating around atm
    1st: normal ecotec conversion (series 1 vs motor)
    2nd: standard eco with a getrag box
    3rd: fav atm, supa 6 with either my T5 or a getrag behind it and change the pulley to put out about 14psi
    4th: 5L conversion with a new T5 to suit the v8
    if anyone has any info preferably the 3rd option that would be great, also open to suggestions and critisism
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    go the super 6, there will be heaps that say v8 but the super 6's are sweet
    The Black Beauty
    VN S
    Dec 2008
    yeh im realy leaning towards the supa 6, just need find out if my t5 will bolt up to it aswell
    VT
    Apr 2005
    QLD
    Quote Originally Posted by TVR-161 View Post
    V8.
    lol
    Thought about an LS1?
    I guess depending on where you are, age etc...you have to think about (conversion engineering approval!) rego, insurance and running costs....THEN think about what you want to do with it in the future. If you are planning on going balls-out with it, then I highly recommend you investigate the LS1.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Stock for stock, in the same body, a super6 will be quicker than a 5L. Nothing beats the sound of a 5L, NOTHING!
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VN S
    Dec 2008
    its hard enough for me to get insurance now cos no one wants to touch an under 25 with a modified car, i would go ls1 but the sheer cos of the motor, gear box and all the custom work to fit it, then engineering it and the cost to run it out weighs it, apprentice wages arent that great. also i want something that i can stick to the v8s and say hello with. to do the super 6 conversion would be easier, ive allready up graded brakes and suspension and it would only have to go over the pits as its fitted with a super charger (mabey) mite be able to get away with it as it is a factory holden engine
    VN S
    Dec 2008
    Quote Originally Posted by STEALTHY™ View Post
    yeh its had for me to choose between the super 6 and a cammed 5L as i just love the roar of a 5L
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by SUSVN View Post
    well choose. Sound, or power?
    cheers sexy
    VN S
    Dec 2008
    with the right exhaust sound comes with power, but i think ill go super 6
    VT
    Apr 2005
    QLD
    STEALTHY™'s Avatar
    Jan 2005
    No V6 can ever sound like a V8. EVER. My mate V6 was the best sounding V6 i've heard, but even he said its nothing on my stock 5L motor.
    cheers sexy
    VT
    Apr 2005
    QLD
    Agreed. Well, with the stock firing order anyway. Apparently there was a Jag V6 with a firing order which made it sound similar to an 8, but it simply isn't one, so why try or even bother?
    It's like having a cat and saying....
    "Ohhhh.....I wish it would bark like my mates staffy....."
    Simple. Feed your cat to the staffy and get one yourself.
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by VT-565 View Post
    Keep in mind a straight 6 has a completely different sound to a V6.
    cheers sexy
    VN S
    Dec 2008
    Your mind is made up then.
    Post pics when you're finished
    may take a while but ill get id done and when i do ill put them up
  15. #15
    VN S
    Dec 2008
  16. #16
    NO CAR ATM.. -.-
    Jul 2006
  17. #17
    VN S
    Dec 2008
    yeh thats why i was going to do the super 6 but ive changed my mind with the help of stealthy and im gonna drop a cammed 5L in, allready had the 5L sourced for a few weeks, not just need to find lumpy cam, intake manifold, sump, k-frame and T5 to suit with tail shaft and 3in exhaust
  18. #18
    VP Executive R-spec
    Jan 2005
    Stock for stock there's little if any difference between the motors and with 10 psi on the super 6 and an exhaust and tune on the 5 litre theres still almost no difference, perhaps the super 6 a tenth of a second quicker. But since you wont have to change gearboxes with the super 6 that might be your cheapest option. I'd choose the 5 litre only because it's a higher quality item
  19. #19
    STEALTHY™'s Avatar
    Jan 2005
    Oh, i was comparing my stock 5L, vs a Super6 VN Calais (so both should weigh about the same).
    And yes, i showed my my burnout vid. No V6 can sound like that.
    cheers sexy
  20. #20
    VN S
    Dec 2008
    Quote Originally Posted by greenfoam View Post
    so i can use my T5 on a super 6?? well now my mind is in limbo, i mite have to get a second vn
  21. #21
    STEALTHY™'s Avatar
    Jan 2005
    You just need a different bellhousing, and possibly different input shaft, not sure on that tho.
    cheers sexy
  22. #22
    VN S
    Dec 2008
    i know its a different bellhousing and input shaft needed for the 5L id just be worried about the strength of the internals, well im still leaning alot towards the cammed 5L so it seems that is the way ill go
  23. #23
    STEALTHY™'s Avatar
    Jan 2005
    They produce similar torque, so you should be worried with either conversion.
    cheers sexy
  24. #24
    VN S
    Dec 2008
  25. #25
    STEALTHY™'s Avatar
    Jan 2005
    For the cost of rebuilding the T5, it'd probably be cheaper to go with a T56.
    Think a gearset was $3000 on its own. PPG might make one now which would be cheaper.
    cheers sexy
  1. twin turbo or supa charger?????
    By benno_ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2006, 10:28 PM
