Results 1 to 4 of 4
Thread: Steering Rack - Easy
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Default Steering Rack - Easy
    when/after installed new steering rack, do you need to top up or fill any fluids
    like transmission fluid, oil, power steering
    or while installed when un doing anything will any fluids leak out
    thanks in advance thanks
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    When you undo the 2 thin pipes at the rack you will lose fluid unless you block the pipes quickly. If you lose fluid you will need to top it up when you put it back together. If you lose too much fluid you will need to bleed the system. After changing the rack you will need to bleed it anyway.
    MY RIDE
    ImAHoon! is offline Banned
    Toyota Camry?
    Oct 2008
    if you're changing the rack, you will obviously be losing the fluid thats IN the rack, so you'll have to top up at least that much.
    COMMODORE VP
    Dec 2008
    Default also just checked out
    not sure if this is right, when you push down on the steering boot the pressure comes out the boot and also goes out the left hand side one 2.
    and....
    after the part where is goes from boot on the right hand side to the out tie rod end, you can rotate
    is that normal
    let me know thanks
  1. VN V6 steering rack into VP V8?
    By jimmyd17 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2008, 11:33 AM
  2. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  3. steering rack
    By homer simpson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2007, 09:56 PM
  4. steering rack
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2007, 04:03 PM
  5. steering rack
    By fergi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-03-2006, 01:35 PM
