Results 1 to 10 of 10
Thread: Front Struts
    VX Berlina Wagon
    Oct 2007
    Default Front Struts
    ok....ive been snoopin through the site...and im a little confused....
    some people are saying to change the front strut and shock...some say its a waste of money....
    im just after a definative answer....
    also whats a decent shortened front strut worth??
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    COMMODORE VR VS LOWERED SHOCK PACKAGE .NEW - eBay Shocks, Struts, Suspension, Steering, Car Parts, Accessories, Cars, Bikes, Boats. (end time 26-Dec-08 10:11:15 AEDST)
    I personally think its worth it, others may not. Personally i find the front to soft and rolls alot as standard. If you put in short shocks then you will need lowered springs too, which you can go a little lower without sacrificing practicality. The shocks alone wont make it handle alot better, its the springs that will make it.
    When you do it you will probably need new strut top bearing plates and you might see a few bushes under there you can do while your at it
    Reaper
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Getting a shorter front strut and shock will be better in the long run. You'll see longer shock life, and better handling. You can just fit a shorter spring, but it may hang loose at full extension.
    The 1972 HQ Kingswood
    VX Berlina Wagon
    Oct 2007
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Morton's Avatar
    May 2006
    Yup. VR/VS struts are completely different from VN/VP struts.
    VX Berlina Wagon
    Oct 2007
    VX Berlina Wagon
    Oct 2007
    by front strut....do you guys mean the front shock??
    or is there another peice which is actually called the strut?
    nobody actually seems to sell "struts"
    hakhawk's Avatar
    Jan 2005
    vn/p have a "strut insert", other wise known as a shock, this is slid into the original strut body. vr/s have a sealed strut body, with the shock as part of it.
    skyper is offline SKYPER
    SV6
    Aug 2008
    LISMORE NSW
    what r u trying to do to it,did i miss the start of your message
  1. front struts for VU
    By djeyecon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-09-2008, 06:58 PM
  2. Help with front struts
    By jacksien in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2008, 07:46 PM
  3. I need help with front struts!
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-03-2007, 08:40 AM
  4. vn front struts
    By bruised in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2006, 10:16 AM
  5. WTB : Front struts for VN V8
    By ElDubya in forum Swap / Wanted to Buy / Trade
    Last Post: 19-09-2005, 10:16 PM
