Results 1 to 12 of 12
Thread: heating issues
    vq caprice 5lt,02vx executive v6,87 vl commy rb30
    Dec 2008
    ipswich qld
    Unhappy heating issues
    im having trouble keeping my vq caprice cool in this hot weather.
    i was thinking of removing fan and installing thermos but looking through
    others threads its a 50/50 choice to keep clutch fan or go to thermos.
    If i do go thermos what is better single or double, i was thinking double
    with one hooked up to thermosat switch to kick in when reaches certain temp and other hooked up to switch in the car that i can switch off and on when needed is this a good idea or wire both together???
    please help as im pulling my hair out... even tho i have none lol
    car
    Jul 2006
    greensy, melb
    if you do go for thermo's the au thermo's work the best cos they are twin and got a shroud, dont bother going for single as it is a waste of money and doesn't do anything unless it has a shroud.
    also get your memcal tuned to be able to turn the thermo's on/off as thats what i have done and it works great, also ive tried the thermo switches b4 and they do work but the problem i had with it is i couldn't get rid of the slow leak from the probe going into the radiator hose
    "A life lived in fear is a life half lived"
    Vp series 2
    Jun 2008
    are you sure the clutch i working right?
    when you spin the fan it shoud stop fairly quickly not spin on for ages.
    Dec 2008
    ipswich qld
    Smile
    Quote Originally Posted by kniever View Post
    cheers for reply have you wired both to kick in at the same time and did you have to upgrade alternator cause mine laggs with a lot of accessarys on unless it needs the brushes replaced
    Quote Originally Posted by centy View Post
    yeah mate the fan stops quick as
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    i have the au twin thermos and never looked back - for whatever reason my v8 used to get close to overheat all the time - had new radiator and fll system flush etc.. could never work it out - anyway - now she sits below half all the time never goes close to getting to half
    Dec 2008
    ipswich qld
    do they kick in at the same time, how did you take the clutch fan out did you just put spaces behind the bolts ???
    car
    Jul 2006
    greensy, melb
    yeh both fans turn on at the same time and i have no troubles with voltage, and yes just put spacers behind the bolts.
    my temp now barely gets over 1/4 b4 the fans turn on + im using a 180 thermostat
    None
    Aug 2005
    Adelaide, SA
    will twin au fans work in a vn s1 v6? also what has to be done for them to work? cheers
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Reaper
    car
    Jul 2006
    greensy, melb
    Quote Originally Posted by cool vr manual View Post
    they will work for a v6 as all you got to do is put them in and connect them up like your original ones, theres just no point in the v6 tho cos the thermo's they come out with are more than good enough
    Dec 2008
    ipswich qld
    None
    Aug 2005
    Adelaide, SA
    oh right, cheers guys i will keep to my v6 one then hehhehe
  1. over heating
    By crew.man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-09-2008, 07:10 PM
  2. No heating
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-07-2006, 12:29 AM
  3. vk heating
    By madamd in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-05-2006, 01:46 AM
  4. over heating
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-12-2005, 09:36 AM
  5. over heating vs
    By bucko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2005, 12:43 AM
