not sure if this is right,
on the drivers side steering rack boot is it normall when you push down on the boot the pressure comes out the boot and also goes out the left hand side one 2.
and....
after the steering rack boot the rod that goes to the ball joint is that supposed to rotate or still?
is that normal
let me know thanks in advance
The tie rod end should have some play in it, should be able to rotate on its bearing... that is, when it's not jammed into your strut
I have no idea about the boot pressure![]()
The 1972 HQ Kingswood
