Results 1 to 8 of 8
Thread: would running water cause heating issue?
    None
    Aug 2005
    Adelaide, SA
    Default would running water cause heating issue?
    hey guys, well i have brought a s1 vn commodore s pack, and it had a heating issue, so i repleaced the waterpump, water inlet manifold gasket, bypass hose, and now all the leaks have stopped but i put water in insted of coolent so i could make sure, it had been running fine on and off, then today it is kinda warm here and it went to 3/4 mark and stayed there, do you think it would heat up like that coz its only running water and not coolent? ill go out and but some techaoly (sp) xtra cool coolent, but just hoping that might be the only issue with it getting to 3/4 and staying there
    thanks
    VT spac super6
    Nov 2008
    Riverton sa
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Was that just sitting there or whilst moving?
    Is there pressure in your radiator?
    Is your radiator blocked?
    It's not the fact that you're only running water, we only ever run water, and never have a heating problem.
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    Vp series 2
    Jun 2008
    yeah things to check
    fans working
    radiator blockage ( possible coolant helps with rust build up to)
    thermostat
    another leak
    faulty radiator cap
    VR Commodore V6
    Sep 2008
    Sydney NSW
    My first check would be to see if you have a blocked radiator or not.
    None
    Aug 2005
    Adelaide, SA
    Vp series 2
    Jun 2008
    yeah you can buy stuff to flush the radiator. get the corosive one that you only leave in a lttle while and enough for 2 or 3 flushes.
    or if you are realy keen then you can take a side tank off and blast it out with a pressure cleaner.
    None
    Aug 2005
    Adelaide, SA
    i ended up flushing the radiator and buying a new heatertap as lastnight when i was at work i say a leak and looked like it was from heatertap. so far its running good again, but payday i will be replacing all hoses, thanks for your help
  1. Keepin the car running issue
    By spike77 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-12-2008, 11:48 AM
  2. water pump issue
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 05:56 PM
  3. VR Fuel issue and running rough
    By Sgt Santa Cruz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 09:45 PM
  4. Water running onto door speakers
    By littlejon in forum Car Audio
    Last Post: 19-09-2006, 05:27 PM
  5. water pump issue
    By krisjanik in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-01-2006, 03:51 PM
