Results 1 to 24 of 24
Thread: HELP!!!!!!vn 5L wont start
    vn v8 calais manual
    Dec 2008
    Question HELP!!!!!!vn 5L wont start
    hey guys,
    i was just driving and car cut out. i checked for spark straight away. nothing at the cylinders, but had spark at the coil. got it home left it for the night.
    started today on it. went to bursons. was going to get a new dizzy. but they sell more ignition/ trigger modules, so i got one. fitted it. no go. checked spark. no spark at coil anymore! WTF!!!!!!!!!
    so went and got a coil!. still no go!
    f*** it!
    so got the racv blokes to come look at it. no spark like i already know and no injector pulse.
    guys like its a cas sensor lmaoo. its a v8 not a 6 i said. his like it has to be inside the dizzy. so anyway.rang up everywhere and no one lists a cas.
    but from reading the forum it could be the hall effect sensor...
    any other ideas guys?
    thanks in advance
    car
    Jul 2006
    greensy, melb
    yeh what you are talking about is the hall effect sensor and i havent had to change one (yet) but from what ive seen it is a **** of a job, you have to pull the dizzy out of the car to get to it.
    "A life lived in fear is a life half lived"
    vn v8 calais manual
    Dec 2008
    YEAH i know its going to be a **** of a job, but anything to get this ****ing thing running!!!!
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Sounds like the hall effect sensor to me too. Probably worth throwing out the old dizzy and getting a whole new one. Possible the plug is just fouled? Could need some unplug - blow on it - replug action.
    The 1972 HQ Kingswood
    vn v8 calais manual
    Dec 2008
    yeahh could be the plug. mmm no idea. i will check it out tomorrow.
    keep ideas coming guys
    VN Calais 5L
    Dec 2006
    buying a whole new dizzy would be the easiest option. the HAS arent hard to change once the dizzy is out, but if your gunna pull it out you may aswell spend the $160 dollars or so (from memory) and buy a whole new dizzy with a new HAS in it already.
    i fixed my HAS in my last 5L only cos the funds werent there at the time (after spending what was left of my pay on an ignition module and a new coil).
    the only problem i had with my HAS was that the clip to hold the plug in had broken so it kept coming loose. fixed it pretty easily though.
    vn 5.0
    Apr 2008
    o my god i got the same symptoms
    i got a NEW
    dizzy
    coil and trigger
    checked all fuses relays
    and still nothn jus cranks and cranks and no go
    let me know if you find the problem a
    vn v8 calais manual
    Dec 2008
    same exact *ucking same.
    new dizzy and all the same parts at vn nut.
    wiring prob i guess
    Morton's Avatar
    May 2006
    Just out of curiousity, what error code is the car throwing at you guys?
    vn 5.0
    Apr 2008
    vn v8 calais manual
    Dec 2008
    hmm im lost, mines going to the mechanics then auto elecs, and if still not fixed she will be going up for sale or getting sold for parts.
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    did u guys time your engines in when changing the dizzy's wont start if its not close, and as to be in diagnostic mode to do it properly. though u can still check the spark side of things while your cranking.
    vn 5.0
    Apr 2008
    yeah i just got mine tdc and when i put the dizzy cap on put rotor button facing to cylinder 1 put it into diagnostic mode
    doesnt your engine have to be running to do the timing
    and yeah still no spark anyway sux man a
    May 2006
    Perth, Western Aust
    yeh engine has to be goin to do timing but you can still do it whilst its cranking or at least check it, mine was way out and wouldnt start had to get a friend to crank it whilst i checked it - wheni got it close it started enough for me to fine tune it as for spark dunno - might have to check the usuals for no spark - coil, ignition module etc...
  15. #15
    vn v8 calais manual
    Dec 2008
    already dont all the modules and coils and dizzy so could be ecu. but how often do they **** up?
  16. #16
    May 2006
    Perth, Western Aust
    i wouldnt imagine they stuff up too often my car was backfiring badly for a bit - didint break anything - turned out to be rotor was snafu but ecu was fine
  17. #17
    car
    Jul 2006
    greensy, melb
    Quote Originally Posted by vnv8calais View Post
    could quite possibly be ure ecu, mine stuffed up a while ago and the car just wouldn't start but just b4 it totally went the car would barely run and was coughing and splutterong like a bucket of ****.
    got home in the afternoon and the car was fine then the next morning could barely start it, you can swap it with another ecu and see how you go, all vn/vp ecu's are the same as im using one from a vn v6 to run my v8 now, just make sure you use your own memcal tho as that would be fine its just the ecu that stuff's up
  18. #18
    vn v8 calais manual
    Dec 2008
    sweet as man thanks... do you have to unsolder the shipboard holding the v8 memcal?
    well the car is at the mechanics now. see if they can find anything.. causes there no power at the coil or dizzy plug. still turns over and fuses are fine and relays ive swaped them about 10 times with working ones..
  19. #19
    car
    Jul 2006
    greensy, melb
    yeh car will still turn over with a stuffed ecu but wont start, and no the memcal is just held in by clips, its hard to miss cos its a blue rectangle box thing on the board
  20. #20
    vn 5.0
    Apr 2008
  21. #21
    vn v8 calais manual
    Dec 2008
    well it turned out to be the 30amp or 40 amp fuse forgot which one..
    closest to the battery for "engine",
    and dizzy timing was out as well lol
    runs alot smoother now and also runs just better all round which is awesome!
    im happy as..
    $800 later mind u.
    thats dizzy, coil, igniton module, and new wiring to suit coil, because eyelet terminals didnt fit, blah blah!!and labour of course
    thanks for all ur guys help!
    cheers
  22. #22
    car
    Jul 2006
    greensy, melb
    glad to hear that its running mate, you must be over the moon to be driving again
  23. #23
    vn 5.0
    Apr 2008
    ouch 800 bucks thats rough as guts a
    but bet ya glad to be on the road again
    mines still in me mums back yard wastin away gona go down there tommorow and spend a whole day on it
    i know its nufn major but finding the prob is the hard bit
    let yas know when i do but
  24. #24
    vn v8 calais manual
    Dec 2008
    yeahh its ***ing sik having the 5L on the road again.... better then driving dads barina HAHAH!! CHEERS guys and happy new years
  1. VT v6 wont start?
    By Soybean in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-07-2011, 06:26 PM
  2. vn wont start
    By william19 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2007, 09:57 AM
  3. car wont start
    By joshsvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2006, 10:04 PM
  4. vl wont start
    By NVE_069 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-09-2005, 05:00 PM
  5. The VN wont start!
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 12:27 AM
