Results 1 to 5 of 5
Thread: Door Pods Questions
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Default Door Pods Questions
    hey first questions, how are the door pods fitted onto the door trims
    and also what is the biggest size speakers you can fit in them
    let me know thanks
    vq caprice 5lt,02vx executive v6,87 vl commy rb30
    Dec 2008
    ipswich qld
    you have to take door card off and screw from the inside, it depend what size you get as to what speaker fits most common is 6 inch i think they go up to 6x9 take in account when fitting you can close the door and it does not hit window winder. hope this helps
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Stock VR/VS pods are mounted to the door trim from behind. Then a seperate part is mounted to the door metal, which holds the speaker. These hold a 6" speaker, or a 6.5" with some cutting.
    Aftermarket ones are screwed onto the door skin, and can be as big as you can find.
    VN s s2 and MY12 sv6 ute
    May 2005
    Darwin
    ive got 6.5 inch splits in my pods but i used mdf spacers to mount the speaker, not the factory speaker cage.
    1998 vt clubsport replica
    Dec 2008
    Perth, NOR
    i used the vs pods on my vh sle and used 3 bits of 16mm mdf to space the speakers away from door and i was able to just get 5x7" alpine splits in there..
    also screwed from the inside of the door trim and there are also 3 screws that go underneath into the door metal..
  1. VR/S door speaker pods in vn ss door trims?
    By dawg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2007, 09:42 PM
  2. Questions about heater and VR speaker PODS
    By VNPOWER in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2006, 03:21 PM
  3. Some questions about suspension, K&N pods and CAI..
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2006, 06:35 AM
  4. WTB: VR/VS Door pods
    By ProMaX in forum Swap / Wanted to Buy / Trade
    Last Post: 25-10-2005, 07:28 PM
  5. Replies: 2
    Last Post: 29-08-2005, 08:01 PM
