Results 1 to 10 of 10
Thread: leaking tranmission oil (auto)
    NO CAR ATM.. -.-
    Jul 2006
    Default leaking tranmission oil (auto)
    im having leaks of oil on the tranmission pan somewhere cant figure it out.. could it be the gasket that **** itself or would it be something more serious?
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    could be either. drive it up on ramps or something so you can have a good look , and see if its leaking through the gasket or coming from above.
    NO CAR ATM.. -.-
    Jul 2006
    i think it would be easier if i took the torque converter cover off.. now im scared haha i hope its nothing to do with above it and its just the pan gasket :|
    Vp series 2
    Jun 2008
    mate if you think it may be the gasket then it has been a long time between services so you realy need to do it now.
    NO CAR ATM.. -.-
    Jul 2006
    its been about 2years since serviced.. only driven the car about 10,000-15,000ks..? but the gasket feels like its broken! i hope its that though i have the corvette servos? would it be good if i got them installed and serviced the trans too? ?? ive heard there bad for the transmission too
    Vp series 2
    Jun 2008
    no they are meant to lock the gears up firmer which means less slippage. slipping wears clutch packs and burns oil so they are a good thing.
    None
    Aug 2005
    Adelaide, SA
    yeah could be the gasket hopefully or when i had my vr i wasnt so lucky and it was the trans pump (i think that what it was called) :S
    so yea hopefully its just as easy as a gasket for you
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Well you can do a service yourself, it's not too hard Just be prepared to make a big happy mess.
    Where on the trans is it? Front, back, sides... get under there with a can of degreaser, spray it all around, let it soak in, then hit it with some water from a spray bottle and wipe it all off with some good paper towels. Once it's nice and clean, take it for a quick spin and see where the oil's coming from
    You need to identify where exactly the leak is, before you go diagnosing it. Could be the gasket, could be the rear extension housing seal, could even be seeping out from the front.
    I know on my car, the power steering is leaking so badly it's getting p/s fluid all over my transmission. So it LOOKS like my T5 is leaking auto fluid lol
    The 1972 HQ Kingswood
    NO CAR ATM.. -.-
    Jul 2006
    nar its not the power steering i fixed that .. its coming from the front of the pan right under in the middle of the torque converter cover
    VN Exec
    Dec 2008
    I had a genius* mechanic put 2L too much oil in the auto trans of my Liberty wagon.. i made the mistake of accepting his word and not checking that he hadnt over-filled it.. and then it blew the brass welds between the two halves of the torque converter as i was merging onto the Eastern Fwy the next day. Many litres of trans fluid being dumped onto a hot catalytic converter = LOTS of smoke. I was displeased.
    * = LOL not really.
  1. adding auto tranmission additives
    By michaelw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2011, 02:14 PM
  2. Replacing tranmission
    By dale1389 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2008, 10:09 PM
  3. Leaking auto transmission fluid
    By Misaprop in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2005, 12:48 PM
  4. Leaking Tranmission Fluid
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-08-2005, 02:48 PM
  5. vc tranmission problems
    By counc in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2005, 02:54 PM
