Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Auto v6 brakes.
    Brin's Avatar
    Brin is offline GOT MANG?
    VN Berlina, VR Exec & VC Vacationer LE
    Sep 2008
    Green Valley, NSW
    Default Auto v6 brakes.
    Help me make my car not sound like a space shuttle is launching when I brake. Also, when braking from a long distance my steering shakes ALOT and my rear end goes out. Note this is under normal driving conditions, like how you drive with Mom in the car. And other conditions, peak hour on the way to and from work etc. Any suggestions as to what may be causing it?
    It was the same with the pads that were in the car when I got it too.. My current pads cost me not alot at all so I didn't expect much. I'm sick of cleaning brake dust off my mags all the time. Are bendix a good go? Or my Mom is swearing by bosche..
    And finally, can anyone suggest a decent brake upgrade?? Something that I can go to the wreckers and get bits and pieces.. I know with big brakes that there'd be only a few mm's between the brakes and my rims..
    Thanks guys!
    Sab
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    The shudder is more than likely warped rotors. You will need to get them machined off.
    Reaper
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    try and find some VP series 2 brakes, theyre much better then the VN ones
    The Black Beauty
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    Default Reply
    does sound like you have warped rotors, also bendix brakes are the best near same as massive calipers, bendix all the way
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    i have the shake in my steering wheel as well...im thinking warped rotors but shouldnt teh brake pedal pulse as well? as mine doesn't really (steering just shakes!
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    I guess the shake is only long distance/speed braking..
    Replaced a rotor way back when I got here as it was warped.
    Upgrading to better brakes anyway and will see how it goes.
    Was told I can do a VT conversion easily, but can get vp v8 brakes for free
    vr berlina
    Oct 2007
    Sunny Coast
    i have got a set of vr calipers you can have. u in liverpool SYD or liverpool BRIS?
    All GO
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    VP Executive S2, VL 5sp Berlina Wagon
    May 2008
    Down South, Adelaide
    Yeah sounds like warped rotors, had it when i first got my car, either take them off your self and take them to a brake place and get them machined if there still within the legal requirements. Taking them off yourself is cheaper then them doing it, plus its easy
    OR
    You could just get Series 2 V6 VP brakes which are 290mm over the 270mm that the vn's are, you probably wont notice any difference.
    As for brake pads, im using bendix but there still pretty brake dusty, and they weren't the cheapest ones to buy either
    EDIT: VN 270mm -> 290mm Brakes
    Was an issue discussed in last couple of days have a read there
    Sleeper Wagon - In the Build
    VP Executive series 2
    Check out My Ride
    Current Mods
    Widened S/C CAI, 2.5" exhaust, Advance headers, no bellmouth, 17" VY SS, Foamy Tune
    Future Mods
    New Car
    Wanted
    MONEY!!!
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    All I can say is don't go too harcore on your brakes because you'll only end up disapointed. VN brakes are bad on the best of occasions. Just get them to an acceptable standard and don't go spending heaps. I bought all new rotors and new bendix pads for my old VN and it made little difference, was very dispointed. As for the VP S2 brake upgrade, I woudn't waste my time for such a little gain, again watse of money. The brakes of a VN are just one of the flaws that you need to live with. You can do the VT calliper upgrade but again, be prepaired to cough up a few grandos, fair enough if you plan to keep the car for years and years to come, but most ditch their cars after a few years.
    I would suggest either get your rotors machined (if they are within machining tollerence) and get some new pads.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i think the only time the V8 upgrade is worthwile is if fitting new slotted rotors and high quality pads. i suggest QFM from GSL Rally Sport (site sponsors) forget bendix. i don't like machining, especially if they are going to be near minimum spec, brakes are designed to turn rotational energy into heat (by way of friction), so thin rotors can't absorb a lot of heat and are therefor in-effective
    Body by Holden, Soul by Brock
    the Legend will live forever
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by Brin View Post
    Hi mate,
    This has been discussed at length many a time!
    Have a look at:
    Best Brake pads?
    Read from about post 15 onwards, right through to page 2...
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VrWagz1's Avatar
    May 2008
    wollongong
    Yeah +1 again for the QFM's, just fitted mine and the braking power has increased noticeably and no squeeling.
    Reaper
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    Ima just go into Commwreck then and find me a decent set from a VR then. Interested in the VT upgrade. Newer is better, im not going to go all out upgrading it, everything iny my car is second hand... lol. I wont bother machining them.... that will be more expenisve and time consuming than just going down the road, getting a set, cleaning them and chucking them in. im on a trainee wage and the vn has to deal with it.
  15. #15
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Untill you put on your 2nd hand rotor set and find they are warped too, DOH.
  16. #16
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    You can buy my brakes, there only a year old same as pad's.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
  17. #17
    Vp series 2
    Jun 2008
    try replacing the brake fuild and check the bearings are tight on the wheels.
  18. #18
    VP Executive R-spec
    Jan 2005
    If you have good pads and the VPS2/V8 rotors and a 1inch master the brakes can be quite good, it's mostly in the pads though
  19. #19
    Vp series 2
    Jun 2008
    Another way to get your brakes to work is to go to the gym and get HUGE legs.
  20. #20
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by Mackurbation View Post
    lol yeh when i had my vn i replaced the front rotors and whacked on some new bendex ultimate pads...made the car stop way better (only cause it had crap pads on it) but still the braking was crap.
    funny thing is now i have a VS with ABS and the braking is waayyyyyyyy better. But i had to move me parents vn the other day and i was doing about 1 kph (very slow) and taped the brake and well yeh "there was none" lol ...im to used to the brakes on me vs:P
  21. #21
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    People would be in alot of trouble if they sold me warped rotors!!
    Plus, I'm quite respected where I get my car parts, I don't believe i've ever been ripped off there. If not they're done stuff very very cheaply. Many try to rip me off and think I know nothing coz i'm female, so now I stick to the one place.
  22. #22
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    Thanks, I might try that
    Quote Originally Posted by centy View Post
  23. #23
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    My brakes used to be very firm with these crap pads, but are now very spongey too.... Pads are in same condition. Meh. I guess i'll try going to the gym like centy suggested???
  24. #24
    VZ AWD One Tonner
    Jul 2006
    People would be in alot of trouble if they had eyesight good enough to see that rotors are warped!
  25. #25
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    Well, if you truly think that, you can ship me a set of your high performance brake pads and rotors free of cost Sounds fair?
    Along with the shockies too, wouldn't mind a new set :P
  1. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  2. Fuel Mileage Holden VZ Wagon(auto) Vs Subaru 2.5(auto)
    By phantomwalker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2008, 06:38 PM
  3. Brakes
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2006, 09:55 AM
  4. Brakes..?!
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-05-2006, 05:31 PM
  5. vz brakes - VT
    By jbourke in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-04-2005, 10:23 AM
