Results 1 to 3 of 3
Thread: crankshaft pulley
    VX Berlina Wagon
    Oct 2007
    Default crankshaft pulley
    hey all..
    my crankshaft pully needs replacing.....just wondering if its just a bolt on job or is there more to it??
    could anyone give us a walkthrough??
    thanks guys..,.
    ImAHoon! is offline Banned
    Toyota Camry?
    Oct 2008
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    You will need a puller but the first obstacle is undoing the crankshaft pulley retaining bolt or holding the crank while you undo it...I have put a socket on a breaker bar and a piece of pipe over it so it touches the ground ..take the pump relay and fuse out and depressure the fuel line so it doesnt start and hit the key..a little risky but it has worked for me...next with the aid of a puller press pulley of the crankshaft careful not to thread the bolts too deep so you dont touch the crank angle interupter drum attached to the back of the pulley.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. Crankshaft pulley ???
    By mattakaspeeedy in forum V8 Development and Modification
    Last Post: 01-11-2008, 04:13 PM
  2. VS V6 Coolant leak around crankshaft pulley
    By vtclubby_98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2007, 07:21 PM
  3. Need Vs Vt Crankshaft
    By ADZ124 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-05-2006, 09:26 PM
  4. Loose crankshaft pulley?
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2005, 03:44 PM
  5. Crankshaft Pulley Bolt
    By sulo2blue in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 12:26 PM
