How much for a Transmission rebuild, mine is slipping massively wont last long
dude it expensive ...
you could just need a service with new fluid/filter and kickdown cable adjustment ..
do what I said above then put bottle of nulon auto transmission treatment in..
if its that bad then get a 2nd hand one fitted ..
are you sure its transmission ? could be stuffed uni joints or diff ...
Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden![]()
Transmission rebuilds will be looking in the vacinity of $750-$1000 depending on where you take it and what you want done.
Try a service first though, drain the pan oil, throw some trans treatment in to help soften up the bands and seals... then see how it goes
I doubt stuffed unis could cause the car to feel like it's slipping between gears. It's almost certainly a gearbox or torque converter problem.
The 1972 HQ Kingswood
try adjusting the cable by your throttlebody my last vn calais was slipping badly adjusted this cable then was fine
