hey, just wondering how hard to change the front welsh plug will be? the one under the sparkplugs (dfi?) module. do u just use the socket to tap it in or is there a way to get them out? also should i undo the (dfi)? module? or just keep it together and take off the radiator hose?
cheers
also what size is the welsh plug, i just tapped it in and the one i have i think is a bit too big, this one is 28mm
Think ya mean "welch" plug![]()
In the gregory's it says to tap the outer near the rim so it goes in further on an angle then grip with vice grips or snipe nose pliers and pull out. To install put loctite 242 on the welch plug and slowly and evenly hammer in with a socket or something that fits inside the plug nicely.
yer as it says but it sounds easier than actually doing it
