Warning light on dash that looks like a circle with exclamation mark in the middle ?
This has just started to come on for about 2 seconds after starting then goes out.Only comes on after starting.I have no idea what this light means.
Thanks for the help.
is it red? i believe its the brake light warning.
had a red circle with exclaimation mark in the middle come up when my brakes werent bled properly
Yeah it is red.I will check for leaks and bleed the system,Thanks for the info
Check your brake master cylinder for leaks and that its got fluid...
also get under each wheel with a torch and check rubber hoses going to calipers as they wear from age and leak ...
If brakes seem fine and no leaks on brake hoses etc ... could be you need flush the brakes with new fluid ..
there is also a light that comes on when oxygen sensor ****s itself ... check engine light ..
if your not sure then look at your book in glove box , explains what all the lights are for.
Vn executive 1990 200,000kms as of 13/6/08 , oil changes every 5000kms since it rolled out the factory , strut brace for hard cornering, kn pod filter, Ngk iridiums sports exhaust..what else can I say I love my holden![]()
You got abs ???
Originally Posted by Smidy
No mate no ABS
