Results 1 to 18 of 18
Thread: VN 270mm -> 290mm Brakes
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Default VN 270mm -> 290mm Brakes
    Went to the wreckers today and got some brakes of a S2 VP (290mm discs and calipers) and a 1" master of a V8.
    Is there anything i should replace before putting any of the above on the car? Also what the best way to do it.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    personally i woulda got a new M/C as you are then assured it will last the rest of the life of the car. otherwise the upgrade is fairly simple. just bolt on really. suggest you get some new copper washers to ensure a leak free seal when fitting brake lines to the new calipers. also make sure you pack the bearing with plenty of good grease.
    Body by Holden, Soul by Brock
    the Legend will live forever
    Vp series 2
    Jun 2008
    new front flexible brake hose.
    about $65 each.
    Then if you have enough left over the rears aswell.
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Ok, what about draining the brake fluid? i have to do that right? How do i do that?
    Also what's the min brake thickness for these rotors?
    The Daily VN T5V6
    355 VN GRP A REP
    VN S1
    Jan 2008
    Was there or is there a big difference in the VN and VP brakes? If the answer is yes im ripping stealing them from my donor car.
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    VP S2 brakes are apprently much better. dno how specifically
    The Black Beauty
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    tell me how it goes i have a set of vr caliper's here, pretty sure all i need is the disk (would be something slotted)
    VN S1
    Jan 2008
    I didnt really feel a difference in there brakes, thats why i was hoping for a good explanation on why the VP brakes would be better. Bigger and age i guess is a good reason to swap em over anyways, and the fact ive got to pull the lsd diff off the VP anyway may as well poach the brakes.
    Vp series 2
    Jun 2008
    rear brakes are the same.
    on later vp, vn fe2 and vn/vp v8's have larger diameter brake rotors and calipers to match.
    the reason they are better is the pads will have more surface area to grab the disk with to stop the car.
    The calipers are rib to increase cooling to reduce brake fad under high load.
    With the diameter being bigger the brakes will be able to grab further out and therefore increase the leverage (distance from center) which will reduce the load on the brakes for the same stopping power.
    Only down side is you may need 15 rims to fir them.
    to bleed my brakes u got a empty syringe (large) and suckeed most of the fluid out of the bottle ontop.
    then used a little to clean out the crap that had settles on the bottom then filled the tank up and bleed the wheels, stating with closest till the fluid was all clear. (my old fluid was blackish green and new was clear)
    Apr 2006
    Auckland NZ
    it's a small upgrade only. bigger rotors will dissapate more heat. both the old VN (actually going right back to VB) and VN V8/VP use the same size pads (DB1056 or DB1057 i think) and same piston diameter in the calipers. the later model calipers do have the fins for better cooling. to really makethe upgrade worthwhile oyu better off fitting some slotted rotors with some decent pads
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Quote Originally Posted by immortality View Post
    I see what you did there. ^_^
    But I have to agree with what immortality has said. It's an upgrade, but not a big one. It's not really a huge difference... until you step up to bigger calipers and bigger rotors with better pads, you're not going to be getting money's worth.
    The 1972 HQ Kingswood
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Quote Originally Posted by Morton View Post
    if you need new rotors anyway, and can get a set of calipers cheap(dont anyone fall into the "VL TURBO" calipers bs, theyre exactlty the same), then its a worthy upgrade, unless you're changing master cylinder aswell.
    theres also one thing that everyone overlooks, it is only a slamm thing, but it contributes to bad pedal feel and some lost braking power.
    the bracket at the front of the master cylinder. get someone to get in the car and push the brakes all the way, and watch the master cylinder from the side, most of the time, it will move 4-5mm. this isnt much, but at the pedal its supposed to equal about 25mm of pedal travel that you're losing.
    i made one up using some 3mm aluminum, a drill, hacksaw, vice and hammer.
    i did the v8 rotors, calipers, master upgrade at the same time, so cant tell you the difference it makes by itself, but overall, my brakes i find are pretty damn good now.
    Apr 2006
    Auckland NZ
    your always gonna get better pedal feel when upgrading the master cylinder to 1" even when fitting the finned calipers because all the calipers use the same size pistons (so you have effectivily increased the leverage force of the brake pedal). i also agree with upgrading the bracket that holds the M/C. i've seen what your talking about and have seen similar upgrades on other cars.
    if the upgrade was free i certainly would do it, if i had to pay for parts i'd go for the VT upgrade instead
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    True but VT upgrade pretty expensive when you compare it to the v8 upgrade. Though rotors and pads are same price range if not a bit cheaper for VT ( calipers cost same aswell from wreckers if your lucky) the hubs and brake lines add another $400 to the conversion
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  15. #15
    VN S1 Executive
    Dec 2008
    Glenhaven, Sydney
    i bought my vn with the vt upgrade already done... brakes are absolutely brilliant by comparison! i'd go for that if you have the cash
  16. #16
    Brin's Avatar
    Brin is offline GOT MANG?
    VN Berlina, VR Exec & VC Vacationer LE
    Sep 2008
    Green Valley, NSW
    purrVN, are you able to post pics or anything of how the VT conversion sits/looks?
  17. #17
    92 Vp Calais 5.0l
    Nov 2008
    the vt conversion is only on front brakes..tru?? and r they straight bolt in o do u have to upgrade other parts of braking system??
  18. #18
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Quote Originally Posted by ibs87 View Post
    for vn/p you need these first before the rotors will fit VT BRAKE CONVERSION HUB ADAPTORS VB VC VH VK VL VN VP - eBay Other Brakes, Brakes, Car Parts, Accessories, Cars, Bikes, Boats. (end time 13-Jan-09 09:36:58 AEDST)
    Once ya got them all sorted then your on your way. You can fit the vt/z rotors calipers on the front. You still may need the adaptor brake lines aswell, not to sure for vn/p
    Reaper
  1. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  2. HSV brakes on my SV6??
    By SV6er in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-03-2008, 01:44 PM
  3. F/S V8 Calipers (290mm) Qld
    By LowVp in forum Parts And Other Items For Sale
    Last Post: 26-12-2007, 09:59 AM
  4. help with brakes
    By markandsam in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-12-2005, 07:37 AM
  5. Brakes
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2005, 05:20 PM
