Results 1 to 21 of 21
Thread: oxygen sensor
    VX Berlina Wagon
    Oct 2007
    Default oxygen sensor
    Does anybody know how to test these?
    tryed looking in my gregorys but couldnt find it :S
    thanks fellas
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Have you got the Engine warning light illuminated?
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    VR Caprice
    Dec 2005
    You can test them by doing a resistance measurement, dont know the reading but I know it can be done.
    Normally when their on the way out the orange engine light will come on when the car is at running temp.
    VX Berlina Wagon
    Oct 2007
    Quote Originally Posted by NeilB View Post
    well...my car has a bit of a rough idol and a laggy take off sometimes......and im all out of ideas...i read that some people are having the same symptoms as me with faulty O2 sensors..but i havent had any warning lights..
    my coils are fine..
    my dfi module is fine..
    replaced leads...
    replaced sparkies...
    replaced injectors...
    Put a BMC air filter...
    Cold air intake....
    i know the crankshaft pulley needs replacing....would that be a factor??
    and sometimes i get this waft of petrol in the cabin through the air vents..
    any ideas??
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Quote Originally Posted by King_berald View Post
    my coils are fine..
    replaced leads...
    Cold air intake....
    any ideas??
    Yeah, have you got an Engine light illuminated?
    VX Berlina Wagon
    Oct 2007
    Quote Originally Posted by crazybiker View Post
    nothing has come up recently...i think about 6 months ago...it might have flicked on once for like a couple of seconds.....other than that...nothing...
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Well then it should be all good.
    If your concerned, just check the ECU for codes.
    Checking your Computer for Faults (VN - VP)
    VX Berlina Wagon
    Oct 2007
    ahk sweet as pie...
    well does anybody know what could be causing this problem i have??
    VR Commodore V6
    Sep 2008
    Sydney NSW
    IAC could be playing up.
    VX Berlina Wagon
    Oct 2007
    VR Commodore V6
    Sep 2008
    Sydney NSW
    IAC?
    Idle Air Control
    It's the little valve at the back of the throttle body that is computer controlled to allow the amount of air going into the motor whilst idling.
    This could be sticking, or the plug might be lose.
    Have a check of that, and also check the error codes and tell us if that lists anything.
    VX Berlina Wagon
    Oct 2007
    ah ill check it out in the morning with a bit of light....how do i check the error codes?? dont i need like that gadget that plugs into the ECU?
    VR Commodore V6
    Sep 2008
    Sydney NSW
    A post I made earlier
    VX Berlina Wagon
    Oct 2007
  15. #15
    VR Commodore V6
    Sep 2008
    Sydney NSW
    sorry i mustnt have read it properly..
    LOL. It's all good. It's pretty easy to skip a post.
  16. #16
    VX Berlina Wagon
    Oct 2007
    checked that sensor...all seems well...cleaned the plug out and stuff...
    didnt fix the problem though...
    also i noticed that my injectors can be rotated...is this a problem? because i remember at one stage that they couldnt be rotated....then i had them looked at...and now they can....
  17. #17
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Not too sure on the injectors actually.
    What about error codes. Did you check those?
  18. #18
    VX Berlina Wagon
    Oct 2007
    yeh earlier this morning...but nothing came up...code 12....which is nothing yeh?
  19. #19
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Yeah.
    I'm not sure. Hopefully someone more knowledgable will come around, other than that, I can only suggest cleaning your throttle body, and checking your IAC valve.
  20. #20
    VN S1 Executive
    Dec 2008
    Glenhaven, Sydney
    well the engine light is a bit of a mystery as it should be coming on if the O2 sensor has died, but all the other symptoms point to that as your problem. Waft of petrol smell is more than likely the engine overfueling and pushing raw fuel into the exhaust. Does the car blow any black smoke and cough and splutter a bit while going up hills or under hardish acceleration?
  21. #21
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I'd Say take the Iac (even the whole TB) out and clean it. Put it back in reset it by disconnecting battery for a bit then reconnect start car and rev to 3000rpm for 30 secs.
    Failing that You said the harmonic balancer neeeds replacing that could be an contributing factor
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  1. oxygen sensor on VN..
    By dylanfh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-06-2008, 09:18 PM
  2. oxygen sensor
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2007, 01:36 PM
  3. Oxygen sensor
    By trevmeister in forum General
    Last Post: 19-11-2006, 01:04 AM
  4. Oxygen Sensor
    By Full Spectrum in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2005, 03:40 PM
