hey guys
justing need some ideas on how to boost my acll pedal response
ppl say bigger tb
or more air intake
but wat are ur guys ideas about making its better
better respone and acceleration best thing is diff gears 3.7 or 3.9 is what you want. Cost a bit to put but better than wasting 150 on a TB that you dont need.
Have you tried adjusting your kickdown cable?? i might not improve respone but shoult make the auto shift better
Originally Posted by Smidy
heyy im a reall car dumbie as im trying learn as much as i can so i really thasnk u for telling me tht stuff
how do i adjust the kickdown wat is a kickdown ahah
and how i go out getting dif gears
wld i go buy a defrent dif
or wat n were wld i go cheers
If you want diff gears done mate go to a diff joint and ask about them its not going to be cheap but theyre worth it. Kickdown cable i honestly forget how to do it properly to tell you how. Theres a little button on the cable (its on the Throttle Body the one at front) then i think you pull it through and fully depress the accelerator cable. Something like that anyways maybe someone else could explain it better than me
@ the wreckers you can pick up them diff gears for around 300 bux.
For a rebuilt one thats installed, you can get away with about 500 bux.
Play around with the button (it doesnt look like a button) on the kickdown cable. will change the way your box shifts - shorter/harder/softer etc
Try a v8 throttle body, its 10mm bigger to my knowledge correct me if im wrong. it bolts straight up to the v6 unit. but remember your engine will only hold as much air as it was meant to.
If you have money to waste on diff gears, do some research, like I said you can get a whole diff rebuilt etc etc installed for that little. I'd go an lsd while you're at it too.
tht really helps alot guys thanks
with the kickdown buttom is it on the tb and do i pull it tighter or wat
