Results 1 to 3 of 3
Thread: VN Fuel Pump Setup
    Renno's Avatar
    Renno is offline Home Of The Shiny Tank
    VN Calais 5L
    Dec 2008
    Defected And In The Shed
    Question VN Fuel Pump Setup
    Hi all,
    I have removed my fuel tank in my 1989 Series 1 VN Calais 5L and atm its gettin sandblasted and in insides cleaned out.
    Now instead of replacing the factory crappy intank pump and external pump, I want to just run a single Walbro intank pump ready for some HP down the road.....
    What is needed to do this? I was told to go with a VN Series 2 sender unit as they supposively run a single pump instead of the early vn twin pump setup?.....but i wouldnt think there was a difference with the intank sender setup?
    Any Feedback Appreciated
    Cheers,
    Renno
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    I have a 91 vn ss and still has the twin pump setup.
    You can replace the external pump with a bosch 044 but you will need a few fittings to step it down to the standard fuel line size. You can use the standard fuel pump bracket once you remove the rubber from inside it or there are billet brackets that you can buy for them. I replaced the internal pump at the same time. The 044 upgrade is very common and no one seems to have any troubles. Capa recomends doing it with their SC Kits. Heres a few phone pics from when i did mine a while ago.
    Attached Thumbnails Attached Thumbnails VN Fuel Pump Setup-dsc00221.jpg   VN Fuel Pump Setup-dsc00227.jpg   VN Fuel Pump Setup-dsc00266.jpg
    Renno's Avatar
    VN Calais 5L
    Dec 2008
    Hmmm ive been told about the 044 setup, but really wanted to just illiminate the external pump....
    Ive had some discussion with a few mates and ill be going with a walbro and the 'longer' series 2 sender...
    Thanks for your help mate
  1. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  2. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  3. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
  4. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
  5. WTB: - EFI Fuel pump setup 4 VK/VL
    By Kim in forum Swap / Wanted to Buy / Trade
    Last Post: 21-12-2004, 09:35 PM
