hi there,have the yellow engine light full on after new battery and regulator exchange any idea what might be causing this thanks.....
run a diagnosis on the car with a paper clip and find out what the error code is go here to see how Checking your Computer for Faults (VN - VP)
go here for what the code meens
Just Commodores - For All Your Holden Commodore Needs
i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
http://robsbackyarddragraceing.bigblog.com.au/index.do
Mine was doing the same thing. I opened up the throttle and sprayed it out with throttle cleaner. You should have seen how much built-up shit poured out. I went through 3 cans. I also did the EGR valve (took it apart and sprayed it). Do around your injectors as well (and if you can get them out give them a hit). If you can do the sensors on the exhaust, it would be good also.
Mine was sputtering also and after cleaning it, it is like a new car.
could be a dirty o2 sensor try some PULP !!!!!!!!!
