Results 1 to 8 of 8
Thread: boot release
    VN
    Jan 2009
    Default boot release
    im sick of having to get outa the car when someone wants to put stuff in the boot so ive got hold of the switch and the acctual opener from the boot have do i hook up the wireing so it all works
    thanks matt,
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Depending on what model your VN is, The boot release is either button operated or handle operated.
    If you after the button in the glove box type, the wiring is already there. Get some needle nosed pliers and through one of the holes near the switch, grab the orange and black wires that are visable. Then connect the two wires to a factory switch (black) (You'll need to get one of these from a wrecker or something)
    Now open the boot, and near the petrol filler, on the inside sould be a length of black wire with a red stripe. This is threaded into the boot lid and connected to a solinoid. (You'll need one of those too)
    Now the boot will open by button in glove box, an if you have an aftermarket alarm, you can also wire it up to open off your remote.
    Hope this helps you out.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    I just got one from a VR/VS that goes beside the seat and installed that, was pretty easy now my boot fly's open!
    I think its better then the button cause i dont have to lean over to open the boot
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    VN
    Jan 2009
    yer i already have all the bits for the one in the glove box just didnt know the wires were there already
    i might relocate the boot button to one of the blanks near the A/c so i dont have to lean over all the time
    thanks guys
    ill go look now
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by VNDUMP"D View Post
    Thats a real good idea, or maybe just add another button on the driver's side somewhere so you got 2
    The Daily VN T5V6
    355 VN GRP A REP
    VN
    Jan 2009
    found all the wires hooked it all up and.................. nothing wont work the switch and the solinoid both work as they came out of my spare parts vn and no fues r blown
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    I got no idea but is it fused? Could not have a fuse in it? Also go over it with a multimeter and check continuity.
    If not try running your own temp wires and see if that work's, if that dose and it was me i would just run my own.
    The Daily VN T5V6
    355 VN GRP A REP
    VN
    Jan 2009
    all fixed the plug in the boot was nackered the wire had been pulled out of the plug
    thx for all ure help such an easy thing to do as well
    ill post pics of my car later today its mint as 127,000 orgional 1 previous onwer now passed away and clean as
  1. Boot Release
    By VP Pursuit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2008, 08:18 PM
  2. how to fix boot release
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-05-2006, 12:56 PM
  3. VN Boot Release?
    By kweenkylie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2005, 04:44 PM
  4. boot release
    By kunifa in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-10-2005, 06:15 PM
  5. Boot Release not Releasing Boot
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2005, 07:30 PM
