Results 1 to 11 of 11
Thread: Need answer quickly!!
    VX Berlina Wagon
    Oct 2007
    Default Need answer quickly!!
    how do i remove the plastic on the peir thats between the front and back doors?
    vp executive 92
    Oct 2008
    newcastle
    im not one hundred percent but it should be held on by clips if you have a trim removal tool ya should be sweet failing that a small flat blade screw driver under it should work as well but be carefull
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    '''missread'''
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Morton's Avatar
    Fairstar the Funship
    May 2006
    The bottom or top piece?
    Top piece: remove the door rubbers and the seatbelt upper, and it should just come off.
    Bottom piece: remove the door rubbers and the seatbelt lower mount. And anything else infront of it
    The 1972 HQ Kingswood
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    my quick answer...just rip it off, just goto the wreckers if you brake it.
    VX Berlina Wagon
    Oct 2007
    sorry...i ment the outside...it has 2 clips or something at the bottom of it...
    Morton's Avatar
    May 2006
    Oh the black one? I'm pretty sure you have to drill out the rivets.
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    theyre push pins at the bottom, get a small screwdriver and push in the center. the pins will most likely drop down to oblivion. then i cant remember whats behind that, clips that either slide or pull out.
    VX Berlina Wagon
    Oct 2007
    so i found out...
    which leads me to my next question..
    is it hard to find and replace the clips that hold em on?
    or am i better off just taking it into a body shop??
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    I'm very interested in this as well! Can you salvage the push pins or is it a silicon job after lol.
    hakhawk's Avatar
    Jan 2005
    just goto autobarn or (insert favourite auto store here) and buy some new ones. take the old clip(minus lost center pin) and find one that matches.
  1. 5 litre has lost a lot of power very quickly
    By stocky in forum V8 Development and Modification
    Last Post: 17-11-2008, 04:50 PM
  2. Just quickly.. how do you adjust the needle on a speedo?
    By shmickmik in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2008, 11:39 PM
  3. VP calais (Auto) Changing gear to quickly, HELP
    By GMHG3N in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2007, 11:00 AM
  4. Overheats Resonably Quickly...Why?
    By GAMBLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 07:01 PM
  5. just need to know a few things quickly
    By Nobody Actually in forum The Pub
    Last Post: 10-01-2007, 02:36 PM
