Results 1 to 16 of 16
Thread: Preparing Tie rods & Ends
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Default Preparing Tie rods & Ends
    Yo doods/homies/friends/companions/lovers.
    What's up.
    I have:
    2x new Tie Rods
    2x new Tie Rod Ends
    The Tie Rods appear to be lubed up with a thick, dark grease. They are quite stiff to pivot on the ball, even after moving around a few times - as compared to the old tie rods, which move easily and freely.
    Is this normal? Or do I need to clean out the new thick grease, and replace it with a thinner grease?
    Cheers in advance
    Mortus.
    The 1972 HQ Kingswood
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Your old ones move freely probably because of the age, Im sure the new ones will work free over time.
    VXII SS M6 & Leather
    Nov 2003
    Warrnambool
    your old ones move freely because they are stuffed - thats why your replacing them.
    everything you have just bought is fine to install as is.
    Morton's Avatar
    May 2006
    Cheers guys Thought that may be the case.
    One more question:
    My new tie rod ends are NOT the type with a split-pin and castelled nut. There is no hole in the tie rod end thread to provide for a split pin, and it was supplied with a nut which contains some of that blue nylon lock-into-place stuff.
    I'm presuming this is a perfectly safe alternative to the castelled nut and cotter?
    VP Exec,Gsx-R 750
    Mar 2005
    Quote Originally Posted by Morton View Post
    One more question:
    Yeah mate, it's just a Nyloc nut. That will be fine.Most of the time with Nyloc nuts too, if the nylon is blue, its Metric thread, if its white, its Imperial.
    Maybe throw a bit of Ant-seize on all the threads of everything too, it will make it easier if you need to disassemble it down the track.
    Morton's Avatar
    May 2006
    Ahhh thankyou Hillerus Champion.
    I was trying to track down some anti-sieze yesterday, but nobody has ANY in stock, except Autobarn who have a massive tube for $30.
    Do not want.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yeah nyloc nuts are meant to be like that they dont come loose and require you to use a rachet or spanner all way the off. You'll find pre vl's use castelled nuts on tie rods and ball joint vn on wards use nylex nuts (true for aftermarket parts anyway)
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Morton's Avatar
    May 2006
    Nylex it is, then I can get used to that.
    VP Executive R-spec
    Jan 2005
    Factory tie rods on VN and VP are castle nuts. I might has a look on the VS and see how far into the future they went since that still has the original ones on it too
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    now, for the hard part.
    I did mine the other day, my question to you is... can you find a place that sells new "lock washers"? i couldnt, so i "fixed" my own.
    The nyloc nuts are total win! they wont come loose... just as good as the castella nuts they use in the old school cars
    its not a hard job and fixes that annoying clunk you get when full lock!
    aZk.
    Morton's Avatar
    May 2006
    Quote Originally Posted by azkwazere View Post
    aZk.
    Ahhhh yes, I just did my lock washer hunt yesterday. I went down to a good steering specialist, and he gave me a couple for free Really good bloke. Old, and knows his stuff well. I tried to pay him for them, and he just told me to come back when I have a real problem
    So if I were you, I'd hit up my local steering and suspension shop next time
    vq caprice 5lt,02vx executive v6,87 vl commy rb30
    Dec 2008
    ipswich qld
    morton pretty sure nyloc nuts are a use once only item, so everytime you take it off replace that nut or the nylon will wear out and well fall off.
    Morton's Avatar
    May 2006
    Yeah that makes sense, kinda figured. It's sort of like a really soft version of a torque-to-yield bolt.
    VP Exec,Gsx-R 750
    Mar 2005
    Quote Originally Posted by 5lt caprice View Post
    That's true, but I've re-used them heaps and never had a problem. When it gets to the point that you can screw a Nyloc on by hand, that's when they are worn to the point of replacement.
  15. #15
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Do not want.
    Supercheap sells it in little packets for about 3 bucks
  16. #16
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    VX have the split pin as well...
  1. Preparing A VR for a looooong drive
    By feistl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2008, 05:47 PM
  2. tie rod ends
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-02-2007, 09:28 AM
  3. Preparing Gas shocks?
    By AGRO_38 in forum General
    Last Post: 15-08-2006, 05:12 PM
  4. it just never ends
    By impakt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2006, 10:23 PM
  5. preparing my VL for painting, need help
    By GH05T in forum General
    Last Post: 03-11-2005, 05:08 PM
