How you going guys, I just installed a keyless entry system to my VN Wagon and it all works fine, except, i have no idea how to connect the unit to the lights so that they flash. The unit has 2 wires (brown with 10a fuses inline) that are labeled Flash Lights, but the wiring diagram is very basic and doesnt tell me how to do it!
Where abouts would i get access to the lights, and how should i go about connecting this thing up?
Its a Warlock system bought from JB HiFi (Dominator AC100 keyless entry + Dominator KG400 remote locking kit)
Thanks alot guys!
remove the steering column shroud and find the wires for the indicators that run to the indicator stalk. this is what i did but i cant remember for the life of me what colour they were. was a long time a go. have a look in a gregory's or a haynes repair manual. they should tell you what colours the wires are.
George
yeh but dont go hooking them up to left or right, as it wont work correctly, well with mine anyway i had to hook it up to hazzards..
also was thinking to hook it up to headlights instead
but just get a test light or volt metre and put the hazzards on then check the wires until it flashes the test light or gives u volts on/off...
i hooked mine up to left and right...work perfectly as there are 2 wires, left and right.
George
Mines hooked up left and right. I think from memory, it's a dark blue wire with a yellow stripe for one of them. Just a circuit tester on the wires and switch on the indicator, if the tester flashes, thats your wire.
