Results 1 to 7 of 7
Thread: Manuel conversion info
    vn executive
    Dec 2008
    Default Manuel conversion info
    i just did a manuel conversion applying a series 1 gearbox to a series 2 engine. There are absoloutly no differences and i will post pictures up soon to prove it. The only difference is the fly wheel in terms of an auto and manuel. An auto flywheel is diffirent to a manuel. Regardless a series 1 flywheel and series 2 flywheel fit on both engines, series 1 and two. No crank shaft needs to be changed, the bow housing is idenctical. The only and only difference is the input shaft, it is shorter on a series 1 which makes your cluth just a little bit more sensative but that can be fixed very easily with a simple spring.
    What i'm tyring to say is that for everybody who wants to do a manuel convertion on there vn - vr dont hesitate caus a series 1 box fits.
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Quote Originally Posted by serb_2_1 View Post
    What you probably had was a S1 or S2 motor or box that looked like the other one. You have been misinformed
    Also, autos don't have flywheels - they have flex plates or drive plates.
    So yeah, I wouldn't go telling all your friends that it'll work - I guarantee you it won't work on anybody else's car. Ever.
    The 1972 HQ Kingswood
    VS 355 Turbo, VN Calais 5L, VE SII SV6 Wag, Mirage
    Aug 2006
    Adelaide, SA
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    The only true part in that whole first post is a s1 gearbox will fit a series 2 motor
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    vp executive 92
    Oct 2008
    newcastle
    i would sooner let my three yr old daughter work on my car than this wanker i mean bow housing lmao
    Morton's Avatar
    May 2006
    Quote Originally Posted by lukieboy View Post
    Your daughter would probably be less capable of causing damage Even if she started hitting it with a doll.
  1. g/box conversion info
    By Reggie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-01-2009, 11:01 PM
  2. vl 308 conversion...info?????
    By natas.308 in forum V8 Development and Modification
    Last Post: 18-04-2008, 03:32 PM
  3. auto to manuel conversion - price??
    By beefcream in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2006, 08:32 PM
  4. need some info on 5ltr efi conversion from 202 efi
    By vk_wagon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-02-2006, 09:56 AM
