Results 1 to 18 of 18
Thread: Backfire help?
    308/SERIES2/VP/WAGON
    Jan 2009
    Exclamation Backfire help?
    Hay all, dis is my first time postinglol!!!!! Ummm.....Anywayz my vp, series2 starts ok then starts to backfire when i accularate, Pls Help?
    Jan 2009
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    Jan 2009
    Angry
    Hi V6, ive changed the sparks! leads! All New. i noticed the fan is not working either? And there is a tapping to? i think that maybe the mainifold lefthand side, ummm why is it so gutless?
    May 2006
    Perth, Western Aust
    backfiring could be DFI module , coil packs, the fan is only a thermo fan so wont come on til its hot enough to come on - u can test by un plugging it and putting it straigh to your battery to make sure it actually works
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Jan 2009
    Um that make sense? some wot, um can you give me a step by step guide 4 taking the coil off and testing it ummm yeh new to all this thnks. lol!!!
    Nov 2008
    Smithton, Tasmania.
    Jan 2009
    Question backfire
    hi there, yep all leads on properlyive just removed the coil pack and put it to the batt/now wotz ment to happen here sory lol!!!!!hehehe.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    you need a multi meter to test the coils. you can get em from dick smith on special from $10-$15 normally
    Body by Holden, Soul by Brock
    the Legend will live forever
    Jan 2009
    Cool backfire
    aaaaaaahhh!!! ok get 1 2moro? Dam i could work thou the night if i had dat chance hehehe!! so illl sit on it tell 2moro then guys thanks so much for your help!!!!!!!
    VN S1
    Jan 2008
    Also check if your water in the top of your radiator has little oil looking bubbles. Just take the cap off and look. May also have a blown gasket.
    Jan 2009
    Cool backfire
    had a look @ dat nah.... no bubble of oil there? thank goodness!!!! Ill check in again 2moro guyz thanks
  15. #15
    Nov 2008
    Smithton, Tasmania.
    You don't *have* to use a multi meter.
    Pull the plug out and see if its sparking...
    Don't blow your self up though.
  16. #16
    Jan 2009
    Apr 2006
    Auckland NZ
    Quote Originally Posted by soop View Post
    very rudementry, although it may indicate that the coil is creating a spark, it takes very little energy to create spark across even a decent size gap under normal atmospheric pressure which is not camparible with what is happening in the cylinder under normal running conditions. a better way to do this test would be to remove the lead from the plug in the cylinder and fit onto a spare plug with the gap opened up some. earth the plug against something of bare metal and then crank engine and see if you get a spark. much less likely to create a very sore hand
  18. #18
    Jan 2009
    Thumbs up
    will give dat a try hah:mmmmm 2moro thanks guyz ill let u all no how i go with dat 1, gotta start somewhere
  1. LPG Backfire protection?
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2010, 01:47 AM
  2. Mad ass crackly backfire
    By SV6er in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-10-2008, 07:13 PM
  3. Backfire
    By vsstock in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2008, 05:21 PM
  4. gas backfire
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2007, 12:07 PM
  5. LPG backfire when starting car (and possible fix)
    By Gravy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2005, 08:36 PM
