Results 1 to 6 of 6
Thread: Knocking noise on start up
    Brin's Avatar
    Brin is offline GOT MANG?
    VN Berlina, VR Exec & VC Vacationer LE
    Sep 2008
    Green Valley, NSW
    Default Knocking noise on start up
    Howdy all
    The VN seems to have a slight little knock/rattle on startup lately.. It doesn't happen all the time, mainly i've noticed at night when it's cold.. I'm told this could be tension on the fanbelt, as it starts moving, but that seems fine so now i'm quering about harmonic balancers?? Possibly? Unless you guys can think of why there is a man with a hammer under there?
    Thanks in advance..
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    can you be more descriptive ofthe knock (i.e. sharp metalic or dull thud?) are you positive the knock is coming from the front of the engine? you can check the serpentine belt tension on the tensioner pulley, it has a wear indicator to show how much the belt has stretched. you can do a quick check on the harmonic ballancer, remove the serpentine belt and see if there is movement by manipulating it by hand. also check the rubber for cracking and degredation.
    some other things to check, oil level/condition, when was the last oil/filter change? what grade oil do you use? what is the engine mileage/condition
    what transmision you running?
    Body by Holden, Soul by Brock
    the Legend will live forever
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    If its just noisy lifter noise then change your oil and put somthing thicker in, or in my old fagna i used some magnetic lucas additive to the oil. Was just some thick runny stuff, but it quietened it down on cold starts.
    Reaper
    Brin's Avatar
    Sep 2008
    Green Valley, NSW
    No its not lifter noise..
    It's just kinda like a little rattle.. three of four knocks
    and immortality, i havent done it yet but if there is movement by manipulating it by hand, what does that indicate? rubber is fine no cracks etc.
    last oil and filter change in october, always used the best oil. engine is a vr v6 just put in there about 5 months back. engine is in top condition I'm pretty sure it had no more than 200 on on the clock but has been looked after. running a vp tranny.
    vn calais, vs clubsport #137
    Jun 2005
    theres movement on your balancer? its ****ed then lol, thats what it indicates . you need a new balancer.
    Apr 2006
    Auckland NZ
    Quote Originally Posted by vn calais manual View Post
    pretty much, if you can move it by hand it's stuffed (unless your 6 Ft 6 and weight like 120kg all ripling muscle
    best oil??? thats fairly vague. do you remember what the specifics?
  1. knocking noise
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2008, 09:43 PM
  2. knocking on cold start
    By FadeToBlack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2007, 05:31 PM
  3. VR Knocking Noise.
    By AussieHolden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2006, 07:27 PM
  4. VP Knocking BAD noise
    By com123 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 09:45 PM
  5. Knocking noise
    By tkaragia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2005, 07:14 PM
