Results 1 to 17 of 17
Thread: VN bonnet wont shut
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Default VN bonnet wont shut
    Hey guys been playing around with my car all weekend with no troubles with the bonnet, then I go to close it today and doesnt want to lock in/shut ? any ideas and how to fix is appreicated!
    Thanks
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Asking the obvious here, but what tools have you left in there?
    Mine did the same, after i slammed it down, i realised i left my old grill sitting on the strut tower haha!
    Can also be a problem if you have fitted bonnet struts, but not taken out the raised bolts!
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    VT Calais 3.8
    Nov 2008
    Make sure your latch (the thing with the spring on it at the front of the bonnet) is screwed in tightly, it can come loose over time. Also, when you tighten it you'll notice it can move around a bit, you may have to experiment with tightening it in slightly different positions for it to latch properly.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    So it shuts, but won't lock shut? Pull the bonnet release in the cabin a few times, jiggle the hinges and clips and latchy stuff and doodads and thingamajigs and just generally **** with everything you can see. Then try again.
    The 1972 HQ Kingswood
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    sometimes its the spring on the bonnet, its either not extended enough or extended too much, u need a flathead screwdriver to fix that. anotherpossibility is that the latch cable that runs from the front of the car around the left side of the engine bay into the car has come loose (usually on the front left of the car) just ziptie it so that it runs smoothe wid the engine bay like the rest of the cable and u shud b sweet. easiest way of knowing is look into the hole dead centre front of the car where the bonnet pin goes into, if u can see a piece of wire run thru it, itl click in, if not you need to adjust the cable mate.
    ave fun
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    Apr 2008
    i have this same problem with my vs. anyone wanna fix it for me? 50 bucks for ya, located in mount waverley.
    cheers
    social's Avatar
    Nov 2008
    South Aus
    id do it but i dnt kno were mt waverly is haha
    Apr 2008
    its in Vic, near chaddy if anyone knows the area.
    it looks to me like the wire is coming out too far, so when the bonnet shuts it hits the wire rather than sliding around it. if i get someone to pull the release, shut the bonnet, hold it down so its right, and let go of the release and she just pops up again...
    really wanna get his fixed coz hols start tomorrow and wanna drive interstate!
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by B3ND3R View Post
    cheers
    You serious? Ill be in melbourne on the weekend if you get really stuck, but im sure someone will snatch it up before then.
    Apr 2008
    quick bump... if anyone can come round tonight and fix it i'll work out a reward!
    social's Avatar
    Nov 2008
    South Aus
    hey mate, get a ziptie (or a few) dependsing on length, and wrapo it around the chassey side of the engine bay and the cable, now tighten it so that it opens when u want it to, thats the simple answer, adjust it tighter and tighter depending on whether it opens or not
    Apr 2008
    got the ****er shut- now it won't open!
    gah anyone wants to come round tomorrow there will be $$$ in it for ya. the bonnet looks to be sitting too far down, as in touching the front bar where as normally a 5-7mm gap.
    social's Avatar
    Nov 2008
    South Aus
    to open it, pull the lever in the driverside footwell, then push down really hard on the centre part of the bonnet at the front, if this dsnt work get sum1 to pull the lever while u push down
  15. #15
    Apr 2008
  16. #16
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    It sounds like you need to adjust your spring... You need two people to get it right.... Remove it, the wind it firm, and keep tightening it from there until you get the best opening. But first you gotta open the damn thing
  17. #17
    VT Calais 3.8
    Nov 2008
    if you can't get the bonnet open you'll need to unscrew the latch while it's shut. To do this grab a long flathead screwdriver and get underneath your front bumper. You should be able to look up to where the spring/catch comes down through the body (the circular hole with the wire latch in it). The end of the catch has a flathead grove in it, just unscrew it a couple of turns and try to open the bonnet as normal, if it still doesn't work you may need to completely unscrew it to get the bonnet open.
  1. Boot wont shut
    By mking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2007, 07:29 PM
  2. bonnet wont lock shut
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2007, 07:00 PM
  3. A/Conditioning fan wont shut off VS
    By kat62 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2007, 04:00 PM
  4. my tappits wont shut up in my vs berlina deos anyone now how to shut them up???
    By lestat21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2006, 09:08 AM
  5. Door wont shut/close
    By VS1Tonner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2005, 02:46 PM
