Results 1 to 14 of 14
Thread: Overheating?
    IvegotaCommy is offline VN Executive S/W V6 3800
    VN Executive
    Oct 2007
    Default Overheating?
    Went for a drive about two days ago. About 150ks and at the end was a dirt road (which I mention because it required slow running in lower range) about 10ks long. Hot day so was running A/C. Stopped the car at the end of the road, switched of the ignition. Motor promptly boiled and dumped half the coolant on the ground via the header tank overflow with much steam.
    Left the car and came back next day. As it happened was no water for about 1km and I only had a 600ml container but no need to go into that. Filled radiator up again and system OK from then on.
    My question is, why did it happen? I think it only boiled after I switched off the ignition. Could it be that the fan wasn't working? Would this cause it? There was no sign of overheating on the temp gauge, reading was on the first division whole trip.
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Um.
    I'm pretty ****ed at the moment, so I'm not thinking straight.
    But water isn't meant to leak from your cooling system at all.
    You had a leak there to start with by the sound of it.
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    VN Executive
    Oct 2007
    Quote Originally Posted by IvegotaCommy View Post
    Just been reading another thread. In it, they talk about 'Rushing sound behind the dash when driving'. I have that same sound. Put it down to either air in the A/C or low level in A/C. Never thought it was the radiator but evidently it is. It gets air in the water or something. Maybe this is my problem? Anyone have a method for bleeding? They never said in the thread.
    VR Commodore V6
    Sep 2008
    Sydney NSW
    I have NO idea what you're talking about there.
    So I'm not gonna advise any further.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    by "dumped half the coolant" do you actually mean HALF the coolant? 5 litres? Or did it just take a ****.
    Because if it just took a **** for a minute, that's normal. When you stopped and turned the car off, the aircon fan turned off, and air stopped moving through the radiator. The only two things that cool the damn thing down. So your car sat there, and heat soaked into the coolant. As it heated up, it expanded, and the pressure rose above 130kpa (or whatever your radiator cap is rated to). As a safety measure, it vented through the overflow runner to the side tank, and once that was full, onto the ground below.
    The 1972 HQ Kingswood
    VN Executive
    Oct 2007
    Quote Originally Posted by Morton View Post
    You may well be right. Just that I have never had it happen before. Also, it's expensive on coolant. Maybe it wasn't half the radiator but it was at least the contents of the overflow tank. Took about a litre to fill the main radiator header as well. So say about 2.5 litres of coolant dumped. Messy and of course it kills grass stone dead so environmentally unfriendly. Ever want some weedkiller, try coolant.
    I will look into getting air out of the system, though. Maybe rig a tube up to the radiator core filler and run and fill? With the heater on. And try running the motor (idling) for a few minutes before switching off. Also, I am wondering if the fan actually runs. Maybe check that, as well.
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    hmm if u leave the key in the on position does the thermo fan on a v6 still work - on my 8 i rigged my thermos to do just that they are temp controlled but turn off with the car but if the temp was for whatever reason high i could stop the car but leave the key on accessory and the thermo would still work till the temp was down - not that it does the twin thermos work a treat
    jackamole is offline Jackson
    VP Executive
    Jan 2009
    I had the same problem just tonight. My VP seemed fine the whole trip running the best ever. temperature was normal the whole time and then when i turned my car off and came back about an hour later, a whole load of coolant was dumped under the engine. I had my radiator and whole coolant system and water pumped replaced the day after christmas, so i dont know what happened.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    sometimes when you overfill the coolant system itll seem fine whilst when you stop it push the extra fluid out of the overflow. I suggest you fill and bleed system properly as stated in how to thread if it still does it look at thermostat
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VL rb30
    Dec 2008
    hi,
    my rb30 vl commodore has been slowly overheating ever since i bought it a month ago, takes about 15mins of driving before i notice the temp needle is 1 bar from max,i have changed the water temp sensor,gets same temp reading, i have flushed the engine and radiator with the hose, i have changed the water pump with a brand new one, i have removed the thermostat all together, i have been using the bleed bolt on the plennum no air comes out of it even after a complete drain of the cooling system. there is no leaks in any hoses that i am aware of....the oil in the engine is at normal level, but, the strange part is when the car temp hits halway the oil light comes on in the dash...but the oil light only comes on at this tempature then stays on until the car is cold again and gets to half way again. and its starting to **** me off because im paying out on parts that obviously have no effect on the problem... any help will be very appreciated
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Does the vl use coolant oil looks fine i.e. no milkyness
    VL rb30
    Dec 2008
    yep oil looks fine,didnt appear to have any water in it, cause i changed that a week ago also, and plenty of greeen coolant, i even removed the aircon radiator from the front of the radiator ripped of its electrical fan and placed it on the front of the radiator and hooked up a switch on the dash yet runnin the electric fan, it has absolutely no effect on the very high temp reading
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    ok you still running clutch fan? maybe clutch fan is gone and wont pull enough air
    Does it use coolant?
    VL rb30
    Dec 2008
    hmmm yeah the clutch fan is there aswell, but the fan shroud isnt...
  1. overheating please help
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2008, 07:13 PM
  2. vp overheating :(
    By RIC_VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2008, 12:30 AM
  3. Overheating?
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2007, 03:07 PM
  4. Overheating
    By Turbo_dreams in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-04-2006, 09:37 PM
  5. overheating vh slx
    By white vn ss in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-02-2006, 05:24 PM
