I dont know a lot about diffs.
What I do know is that i have a standard LSD from a VP commodore which was linked to an auto box.
Do you guys know what i will need to change because i will be running this diff off a manual box?
And where can i get higher ratio gears from. like 3.4* or somthing?
My Commodore - http://forums.justcommodores.com.au/...executive.html
V6. Cat Back Exhaust. 18" Rims. Homemade CAI. Lowered to the max. Sound System. Klaxton Air Horn - "Ahooooooogah"![]()
VP PARTS F/S ENGINE/BOX
No changes need be made at all if you're just changing centers.
The most common, sensible final gear ratios are 3.45, 3.73 and 3.89, and you can either chase them yourself at wreckers (do your research into which gears come from which cars - skylines, pintaras, vl commodores, etc) or you can find them on ebay.
The 1972 HQ Kingswood
read this diff, all you need to know
Body by Holden, Soul by Brock
the Legend will live forever
Thanks very much, might go to the wreckers and search for some.
go to race shift if u want ur diff gears done 550 fited i think it is,well thats for 3.9s shud be all the same i'd imagine.
Where abouts? My local is bear's diff and gearbox. They worked on my brothers VR.
$550 - that was supplied too, right?
3.73s are probably the most expensive gears - they're rare as anything. I wanted 3.73s and had to wait FOREVER for a set of them to appear for sale![]()
$250 for a set of 3.7 gears or
$130 for a set of 3.45/3.5 gears. cheap or what cause i dunno.
Can't get a hold of the 3.7s anymore.
It seems as if i can buy the set of 3.45/3.5 gears for $130. Is this worth just the gears guys? I can get a local shop to fit these gears to my LSD. Will I notice a major change with this set of ratios or should i not bother? Cause atm this LSD has standard ratios.
