hey wat do you have to remove/ undo so you can get the springs out?
What springs?
The 1972 HQ Kingswood
front coil springs
sorry should of explained better
front springs:
1) remove wheel
2) remove brake caliper
3) remove hub and bearings (I prefer to)
4) unbolt and bash out tie rod end ball joint
5) unbolt and bash out lower ball joint
6) unbolt strut top
7) remove strut
8) compress springs
9) hit strut top nut with a rattle gun
10) remove strut top and bump stop
11) remove springs!
Morton, dude you up way too early! Or you still goin on friday nite mate HA HA HA.
My advice is to undo the strut top nut before you lift the car, save having to use a rattle gun.
Also instead of bashing out the ball-joint, just undo the Lower-Control Arm at the K-Frame.
Also leave the hub and bearings alone, too much hassle for a small job
A bit of determination and a want for the highest standards doesn't cost that much!
ANYONE GREEN WITH ENVY
How To: Change Springs/Shock
this site has a how-to section for a reason, a lot of the basic or common stuff for especially early commodores has a how-to written for it
