Results 1 to 16 of 16
Thread: Are VN s2 lifters hydraulic?
    VN Executive
    Sep 2007
    Default Are VN s2 lifters hydraulic?
    The title is pretty much the question, my lifters are ticking and I need to know whether to bleed them or not
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yes they're hydraulic. not sure if bleebing will help. U can pull them apart and clean them then refill with oil and they should be all good
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VN Executive
    Sep 2007
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    bleed lifters? maybe try running some clean oil and oil flush and see what happens.
    Body by Holden, Soul by Brock
    the Legend will live forever
    VN Executive
    Sep 2007
    The problem with them is that they are ticking, and my VN is searching for idle a fair bit and I thought they might be related
    VR Commodore V6
    Sep 2008
    Sydney NSW
    When was the last time you did an oil change?
    Is it ALL cylinders, or just one in particular?
    Are you sure it's not just regular injector noise?
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    VN Executive
    Sep 2007
    I filled the car last week with oil, still says its full... nah the sounds definatly the lifters, not sure which ones just yet and not sure what difference sorting them out will make
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Did you just top up the oil, or did you replace it?
    VN Executive
    Sep 2007
    Topped it up, but It had a service recently and they did that then. the oil was pretty low and I heard that causes the lifters to tick. The engine struggling with idle might be different
    Apr 2006
    Auckland NZ
    rolling idle would most likely be a vacuum leak of some sort. also try cleaning the IAC valve on the TB
    VN Executive
    Sep 2007
    Thats not the part which is removed from series 2's to make them go abit harder is it?
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Mordred View Post
    no, thats the bellmouth inside the manifold. have to remove the TB and elbow to get to that
    vks
    vks is offline
    1990 vn 3.8 S pack
    Jun 2005
    Apr 2006
    Auckland NZ
    Quote Originally Posted by vks View Post
    i think they r roller lifters 2 rnt they?
    yes they are, all the holden V6 engine use roller cams as did the last of the 5ltr 304's used in the VT s1's before they fitted the LS1's.
  15. #15
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yes but they're still hydrualic they just have rollers on the base instead of a solid flat surface. A little late i know but still valid
  16. #16
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Thumbs up Good quality oil
    I brought a '91 VP wagon and it had done atleast 40,000 KLM'S without oil and filter change was planing on doing a service but drove it for a couple of days and one morning just started ticking like crazy(LIFTERS), so turned car off went down brought new filter and some good oil and bout 20 KLM"S later it stopped and i haven't heard a thing since she just tick over 206,000 KLM'S!!!
    Maybe try a better quality oil?
  1. Anyone know anywhere to get cheap V6 ecotec hydraulic lifters?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2009, 01:46 AM
  2. hydraulic clutch??
    By jazzawithvg38 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2008, 10:19 PM
  3. F.S. Hydraulic Lifters New suit V8 and 202's
    By Pub247 in forum Parts And Other Items For Sale
    Last Post: 30-04-2007, 10:14 PM
  4. Hydraulic Lifter Help
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 07:34 PM
  5. Price of new hydraulic lifters and camshaft?
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2006, 12:12 AM
