I want to polish the metal strips that run around the side windows of my VN wagon.
I can see how to remove most of them. But.......
As mine is a Wagon, can someone explain how the strips that are around the rear quarter windows are removed? Does the window have to be removed?
I am okay with the lower strip that runs just above the quarter panel, its the ones that are around the roof guttering that have got me confused.
Any tips on someone who has done this task would be very helpful.
if you take of all the plastics around the window on the inside of the rear window there is around 10 or 12 nylon nuts which once undone your window should just pop out. you need two people one on the inside and one on the outside so the window doesnt break when pushing it out
once the window is out the are a couple of screw holding the top gutter trim on and just clips holding the back bit
beware be very careful removing the plastics as the break very easy as i broke all mine when doing the same thing
Idenity Crisis
VN toyota lexcen/Holden Commodore
Vr Front end, Vs interior and a calais dash
Thanks Idenity Crisis, that is a big help.
(starting to think that the effort is not worth the result, car is only a dirter)
(but I love it)
VNWazza
