Results 1 to 11 of 11
Thread: Throttle Body Upgrade..
    vp berlina 5.0
    Nov 2008
    Question Throttle Body Upgrade..
    G'day
    im looking to upgrade my throttle body and was told a 5.7 throttle body would fit on a vp 5.0 ?
    is that true ,if not what would you recommend ?
    also would there be a noticeable power difference from this.
    the motor is standard but i have cai ,upgraded exhaust and a tuned memcal if this info helps.
    thanks
    Vp series 2
    Jun 2008
    mate just get a bored out job from ebay and then hook up a pod or panel filter to go with it.
    the idea is that a bigger tb gives you faster response.
    vp berlina 5.0
    Nov 2008
    Talking Throttle body
    i didnt know the standard throttle body could be made bigger.
    i shall hit ebay etc now and see what's available.
    thanks for the info
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    you can get a 70mm TB for the 5ltr. i think you also need to modify the neck in the manifold however to get real gains from it
    Body by Holden, Soul by Brock
    the Legend will live forever
    vp berlina 5.0
    Nov 2008
    Quote Originally Posted by immortality View Post
    ok thanks
    so i assume to modify the manifold i gotta take it of ?
    i know the basic's but when it comes to stuff like this im absolutely hopeless.
    thanks
    VN S1
    Jan 2008
    If you buy a 70mm throttlebody you will then be restricted to the size of the elbow the throttlebody connects to, A bloke on ebay and mace engineering do both. They have 'bored out' versions of each. I know mace was selling a throttlebody and elbow with a tune to suit for 300 or so.
    vp berlina 5.0
    Nov 2008
    Quote Originally Posted by needwork2-4fillhabbit View Post
    No worries ill definatly check it out.
    this is probably gonna sound stupid but is the elbow actually welded to the manifold or bolted on ?
    for $300.00 it's definatly around my price range ,thanks to a revenge seeking ex !!
    thanks for the info.
    VP Executive R-spec
    Jan 2005
    The neck on the banana is like 69mm at its smallest point so you only have to give it a quick touch up, Just make sure you seal off the inside before you start grinding and make sure you get all the cuttings out once your done (vaccum etc)
    vp berlina 5.0
    Nov 2008
    Quote Originally Posted by greenfoam View Post
    ok im not that great with tools either and not much confidence in myself when it comes to modifications but if thats all it is i couldn't see it costing a lot to have someone do it ?
    ill go out now and have a look..
    thanks for your info !!
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    or get on a lathe yourself takes about an hour to bore out, polish and make the butterfly plate
    vp berlina 5.0
    Nov 2008
    Quote Originally Posted by Zuicider View Post
    yeah if i knew what i was doing i would but im hopeless with stuff like that.
  1. Throttle body and memcal upgrade
    By Swathe in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2008, 03:52 PM
  2. Upgrade V6 Throttle body???
    By MXBM in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-08-2006, 07:27 PM
  3. 70mm throttle body upgrade
    By jdjones in forum V8 Development and Modification
    Last Post: 23-09-2005, 11:48 PM
  4. THROTTLE BODY Upgrade
    By soulyouth in forum V6 Development And Modification
    Last Post: 11-07-2005, 01:25 AM
  5. THROTTLE BODY Upgrade
    By soulyouth in forum General
    Last Post: 16-03-2005, 02:08 PM
