Results 1 to 12 of 12
Thread: Vn clutch fan bolts on pulley
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Default Vn clutch fan bolts on pulley
    Hey guys the bolts that are used for the clutch fan that are in the front pulley, im having troubles getting them out due to the pulley spinning while trying to ratchet them out... advice?thanks
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Use another ratchet or spanner on the opposite bolt, and force the opposite way Do this working around in circles, (and I know at first this tightens some bolts) but eventually you'll get to a point where they're all a little bit looser and easily removed.
    I personally use a spanner with a steel pole over the end of it, resting against something solid, then just go nuts with another double-spanner or spanner-pole on the other end.
    The 1972 HQ Kingswood
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    The opposite bolt? wont be able to get another ratchet in there unless im not understanding what your saying. Im talking about the waterpump pulley... ill go have another crack anyway
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    You wont be able to use a ratchet, just use 2 ring or open end spanners.
    One on one side holding it from spinning, and the other to undo them. Its a bit awkward but not hard at all
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    I wont be able to get anything behind the pulley to hold the other end, thats my problem..
    Heres a pic anyway
    Attached Thumbnails Attached Thumbnails Vn clutch fan bolts on pulley-vn.jpg
    car
    Jul 2006
    greensy, melb
    hold one bolt with a ring spanner and undo the others with another ring spanner then when 3 are loose turn it so you hold one of the loose ones with a ring spanner and undo the last tight one
    Attached Thumbnails Attached Thumbnails Vn clutch fan bolts on pulley-vn-1.jpg
    "A life lived in fear is a life half lived"
    Morton's Avatar
    May 2006
    Yep. Thanks for explaining what we couldn't be bothered to, kniever
    Also, you're not running a clutch fan. Why don't you have spacers behind your bolts? You should
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    leave the V belts on (tight) and undo all the bolts that are coming off before removing the V belts
    Body by Holden, Soul by Brock
    the Legend will live forever
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Quote Originally Posted by Morton View Post
    Putting the clutch fan back on previous owner had a useless thermo was to small for the motor so bought a clutch fan off reaper. Anyways cheers for the pic now I understand what morton was trying to explain!
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Morton's Avatar
    May 2006
    Glad you got it sorted Clutch fans are good.
    vnss
    Jan 2005
    s.e melb
    i usually jam a long screwdriver against the shaft and one of the bolts rotating as i go until all are loose
  1. Flyweel Bolts S1 (6 bolts) How Do i Remove? Reverse or Normal?
    By social in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2009, 10:54 AM
  2. Stuck bolts on pump pulley - Any thoughts?
    By Radar in forum General
    Last Post: 12-09-2008, 05:57 PM
  3. cat bolts
    By ear099 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2007, 03:14 PM
  4. tightening water pump pulley bolts - how!?!!?!
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2006, 10:30 AM
  5. help tow bar bolts
    By kegzcp308 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-12-2005, 08:56 PM
